SuperCrew
Automatic Headlights
Old Dec 11, 2001 | 07:44 PM
joeeyo's Avatar
I have the auto headlight option on my truck and for the most part I like it. Is there a way to adjust when the lights come on???? Where is the sensor located?????
I do wish the driving lights come on with it, but the truck is 3 weeks old, I do not think I am ready to mess with it yet as per an earlier posting!!!!!!
THANKS ALL!!!
Joey "O"
Old Dec 12, 2001 | 10:34 AM
XTRUKY's Avatar
On your dash
there is a long oval plastic thingy on top of your dashboard
on the passenger side. There is about 6 clips, wedge up one end
and then stick your fingers under and pull up slowly to remove.
on one side there is a set screw that adjusts time on.
search on autolights for further info
Old Dec 12, 2001 | 10:42 AM
LightningCrew's Avatar
Joeeyo - Congrats on the new truck. I understand about your hesitation on the fogs, but just to let you know, I did the foglight switch mod months ago and have had no problems with it whatsoever. I don't use the auto light feature because since I did the foglight mod, I like to run around with just the parking lights and the fogs (until it gets too dark, of course!)
Old Dec 12, 2001 | 03:26 PM
buschman's Avatar
be careful adjusting autolamp sensor!
FYI -
The set screw on the autolamp sensor is VERY touchy - you don't have to turn it much to adjust it and if you turn too far it will break.
Old May 5, 2002 | 08:05 PM
LakeSands's Avatar
I hate to revive such an old thread, but can anyone tell me which way to turn this adjustment to make the lights come on sooner? I tried counter (or loosening), but have not had the chance to drive it yet. Does that sound correct? Thanks
Old May 7, 2002 | 10:06 PM
scooksey's Avatar
Sounds like you did it right. Just hope you didn't turn the screw too far, it's very sensitive. Good luck with it.
Old May 8, 2002 | 10:06 AM
LakeSands's Avatar
I turned it about 1/2 turn, but so far I don't think it really made any difference. I guess I will try turning it a little more.
Old Jun 14, 2012 | 05:05 AM
Racing Truck's Avatar
I am unable to enable my Autolights completely. Only the Headlight comes on in Dust and shuts off in dawn. Replaces Switch and Sun/light sensore. Securit module checks good.
Does anyone have any sugestions?
Thanks,
Brad
