SuperCrew
I need a favor
Old Sep 12, 2001 | 04:34 PM
adamski's Avatar
I need a favor
I need some help from one of you guys. If someone could tell me how many pins there are on the connection for the Mass Air Sensor. My truck is currently in the shop and the service advisors are idiots, and will not help me. It should either be a 6 or 8 pin connection for the 2001 Screw with the 5.4.
Thanks in advance for the help!
Old Sep 12, 2001 | 11:02 PM
2001screw4.6's Avatar
Post
adamski,
There are six pins on the connector and four wires are used, the pins are in a line and pins 1 and 6 are blank. Pin 2 is power from the battery junction box. Pin 3 is a ground on the firewall. Pins 4 and 5 go to the Powertrain control module. I hope this helps you.
Old Sep 13, 2001 | 12:17 AM
adamski's Avatar
Thanks! I appreciate the help, however, I have the 5.4 and I am not sure they are the same in size and connections. If you know, please let me know, and all will be well!
Thanks Again!
Old Sep 13, 2001 | 11:06 AM
adamski,
I have a factory service cd and that is the correct info for your truck.
Old Sep 13, 2001 | 01:05 PM
adamski's Avatar
Thanks!
