SuperCrew
Stinky A/C
Old Aug 27, 2001 | 05:32 PM
Dover's Avatar
Unhappy Stinky A/C
Do I want to leave my switch in the panel position to avoid mold build up and a smelly A/C?
Old Aug 27, 2001 | 05:44 PM
IMud's Avatar
Unhappy Not much choice
You really don't ahve much choice but to run the fan for a couple of minutes on a high setting while set to panel to help dry out the box. It is amazing though how much of a difference that makes even here in Houston where it is humid all the time. I suspect that in AZ, the dry air should make it work better.
Chuck
Old Aug 28, 2001 | 04:44 AM
Mach1's Avatar
Make sure the drain tube stays freeflowing....
Old Aug 28, 2001 | 07:54 AM
bwingate's Avatar
To get rid of the existing stinkiness, spray about 1/2 a can of Lysol into the AC intake vents (on the hood). Lysol is basically the same thing that the dealership will use to do the same thing.
Bruce.
