SuperCrew
old question coming back again
Old Nov 20, 2012 | 09:38 PM
dburgjohn's Avatar
dealer
after failing myself and all non-dealer shops I trust failing I took it to the dealer Monday afternoon. After sitting all night to chill, they start it this morning and it runs perfect. I said keep it one more day. Temp supposed to be down a little tomorrow. We will see
Old Nov 22, 2012 | 09:29 AM
papa tiger's Avatar
swap in a maf out of the parts yard.
Old Nov 22, 2012 | 10:46 PM
dburgjohn's Avatar
MAF, IAT and IAC all new
Old Nov 22, 2012 | 10:48 PM
dburgjohn's Avatar
got truck back from dealer. $72 bill for new fuel pump and cleaning the TB. It does seem to run a little better, but the cold weather rough idle is still there. Crap
Old Nov 23, 2012 | 12:08 AM
papa tiger's Avatar
I'll hazzard a rough guess. Look for the vacuum leak. It may be anywhere. "even the pcv system."
Old Nov 23, 2012 | 02:24 AM
I like Fords to's Avatar
have you tryed snugging down the intake manifold bolts ? or the ones at the throttle body?
my 01 makes a slight vac leak sound till it warms up on colder days but when warm it's ok
I'm figureing that's what mine needs - it can be a little ruff & chunky on cold mornings too
I'd forgotten about it untill it got colder out again - when warm I have no issues with it
Old Nov 23, 2012 | 03:06 AM
Veteran: Army
Originally Posted by dburgjohn
I posted this a few years ago. I and all the local shops have been unable to solve, so why not try another post?
when the temp gets cool, the idle gets rough. all winter long, runs great in the summer. Replaced van hoses and IAC twice. Can't afford to move to FL, would sure love to fix for Tennessee winters.
thanks
it's been in the 70's there in the "southern state of Tennessee"
Old Nov 23, 2012 | 10:46 AM
papa tiger's Avatar
Try isopropyl in the gas tank. Look for a crack in your intake by removing it and searching for damage. Even around the Maf or hose clamp, even inside the air box all the way back thru the entry point. U are accomplishing something this way, removing 1 thing at a time from your list. In the end pull the intake manifold and redo, just crossing it off your list of things to do today. Even a crappy connection at the EC"U for the fuel injectors circuits. Pull the ECU and inspect it for burn/corrosion in/on it. Internal circuit damage. Just croos em off the list of TTDT. Never a quiet dull afternoon in the future. LOL
Old Nov 30, 2012 | 09:11 PM
dburgjohn's Avatar
two new clues
just noticed something. When you start the truck there is about 15 to 30 seconds or normal idle before the roughness starts. But if you shut the truck off while it is idling rough and start it right back you get the same 15-30 seconds of smooth idle before the roughness starts. it does this when the truck is first started or if the truck has been running long enough that the temp gauge is showing normal operating temperature.
also when it is idling rough, the exhaust really stinks, not sure if it is a rich smell or just a funk, but it stinks
the truck still logs lean bank one and two codes
Old Nov 30, 2012 | 10:52 PM
jgger's Avatar
When you first start it the PCM thinks everything is normal. Then after the sensors start reporting it adjusts it's self because of the lean codes. That explaines the 15 to 20 seconds of bliss.
Remember that the lean codes make the truck run richer as the PCM tries to compensate for the air leak, this is very bad for the cats.
Go over EVERY vac line to look for cracks or breaks. Check the vac box by the battery for cracks and good connections. Then examine the complete PCV system.
After that if no issues are found then start the rip and tear that Papa Tiger suggested.
You have a major vac leak somewhere.
Good luck.
Old Dec 1, 2012 | 12:19 PM
InfernalCombustion's Avatar
I recently got an error code on my 2001 that showed a vac leak as a possibility. I was amazed at how many little rubber vac tubes there were. I replaced all that could be accessed easily and found that most just crumbled when I rubbed them between my fingers. And it ran fine! I think i recall three different tube sizes...
Old Dec 2, 2012 | 08:47 PM
VTX1800N1's Avatar
With that many miles, have you replaced the O2 sensors?
Old Dec 6, 2012 | 12:22 AM
dburgjohn's Avatar
no but I have wondered about them. If they were failing and reading lean, the computer would make the mixture too rich causing the rough idle and smelly exhaust.
What I don't understand is how the failure could be triggered by cold weather.
any ideas?
Old Dec 7, 2012 | 01:01 PM
dburgjohn's Avatar
if it blows up...
bought a small propane tank and fitting today. Going to try to find a leak. If it goes boom, I guess it wont matter where the leak was. Perhaps the best solution would be to use the tank the way they did at the end of the first Jaws movie.
Old Dec 9, 2012 | 10:00 AM
For that you're going to need a bigger boat....
