SuperCrew
a little help
Old Apr 15, 2012 | 08:21 PM
Rickey Burgess's Avatar
a little help
i have a 2001 ford f150 supercrew and i have a 8.8/3.55 rear axle in the truck. will a 9.75/3.55 fit in my truck just wondering.
Old Apr 16, 2012 | 12:53 AM
jgger's Avatar
The whole diff will with maybe a drive shaft mod.
The 9.75 gears will not. A 9.75 has a 9-3/4 inch ring gear, the 8.8 has an 8 7/8 inch ring gear.
Old Apr 16, 2012 | 07:26 PM
so what exactly do i got to do to make it fit then i am lost on this
Old Apr 16, 2012 | 10:08 PM
jgger's Avatar
If you are talking about trying to put 9.75 gears into an 8.8 diff? You can't.
If you are trying to put a complete 9.75 rear end in then it should pretty much bolt up, but the drive shaft will probably need to change.
