SuperCrew
Adding 3" Body and Gears to my truck.....
Old Apr 1, 2011 | 01:15 PM
txmoon's Avatar
And here is the finished product....
Old Apr 1, 2011 | 01:29 PM
str8t six's Avatar
looks badass man!!
Old Apr 1, 2011 | 03:56 PM
txmoon's Avatar
Thanks.
Old Apr 1, 2011 | 05:45 PM
4x4wolf's Avatar
Man that looks sweet
Old Apr 1, 2011 | 06:01 PM
wookie13's Avatar
Looks Awesome!!! I like your bar behind your cab! I know its a Go-Rhino but when I contacted them they said it would not work on a screw! How did you mount yours if you dont mind me askin! I want a polished one for my Blue 02 screw!!!!!!!!!!!!!!!!!!!
Old Apr 1, 2011 | 07:08 PM
txmoon's Avatar
Ill take closer pictures for you. But its just held down by 4 bolts with nuts. I placed the light bar where I wanted, marked where I wanted the holes and drilled thru the plastic and bed.
Old Apr 1, 2011 | 07:30 PM
txmoon's Avatar
Here u go
Old Apr 1, 2011 | 09:45 PM
wandell's Avatar
Looks great!
Just a suggestion. You should consider installing GM towhooks like I did. Really cleans up the look of the front end.
Old Apr 1, 2011 | 10:06 PM
str8t six's Avatar
Originally Posted by wandell
Looks great!
i agree with this, but dont do it if you off road alot and get pulled out often. i have ripped chevy tow hooks in half. the closed loop of the fords is much stronger. but for cosmetic purposes the chevys work fine.
Old Apr 2, 2011 | 11:41 AM
txmoon's Avatar
After looking at the picture i took for you, i noticed that the side bars flare out a little bit. That probably why they say it wont fit the screw, When i ordered it I remember it said that i wouldnt fit either but I orderd it anyway because i didnt see how it would fit a screw but would fit a reg 150.
Old Apr 2, 2011 | 11:46 AM
txmoon's Avatar
Looks great!
Thanks for the suggestion Wandell, but i like the stong closed loop design, Ive given some pretty strong tugs, to pull people out and have had no problems.
Old Apr 14, 2011 | 09:48 PM
txmoon's Avatar
Rear 4:89s are in....
So I finally had time to install my rear 4:89s. First time doing it so i hope all goes well. Im not going to go into details but i do want to offer some VERY IMPORTANT ADVISE.... If you are going to install 4:89 Motive Gears the ring gear is thicker. The cross pin will not go in because of that. Efuehrin's gear write up he grinded down a tooth well the way i did it was grinded down the cross pin flat on one side and it slide right in. I wish i would have taken pictures but i was in a hurry to finish the swap before the shop closed. After driving home i could tell a huge differance.
Old Aug 15, 2011 | 08:16 PM
txmoon's Avatar
12aug2011 update.
New CB and relocated GoLight control.
Old Aug 15, 2011 | 09:35 PM
str8t six's Avatar
same spot i put my cb, did you get a PA speaker too?
Old Aug 15, 2011 | 11:05 PM
txmoon's Avatar
Yes I did, I mounted it between the grill and the rad. condenser. Ill take a picture tomorrow and post it.
