Help with splicing into high beam wire???
Finally got around to wiring up my Piaa's and I'm not sure what wire to splice into. I want to tap into the high beam wire, but where is the best place to do that??
I'd prefer to go under the dash, but if the best place is at the light, then so be it.
Just tell me where!!
Thanks!
<A HREF="http://www.f150world.com/LakeFisher/" TARGET=_blank>
Click for more pic's of my S'Crew</A>
2001 SuperCrew XLT 4x4 GenIII - Ordered: 2/17/2001, Received: 4/03/2001
Black/Dk Graphite, 5.4L, Capt Chairs, CD Chgr, Lmtd Slip, Tow Pkg, Skid Plates, Sliding Rear Window
Mods:
Ford Tubular Nerf Bars, Ford/Duraliner Bedliner, Ford Bugshield
305/70R16 Cooper A/T's on 16x8 Eagle 143's
Ravin Z55 Performance Dual Exhaust with 3" Chrome tips
GoRhino Sumatra 3000 Grille Guard
PIAA 520 Lights
K&N Filter
Helix Power Tower
Mods coming soon:
Stull Billet Grille
Future Mods:
SuperChip
Bed Cap
AAD F1-Hood
Thanks!
Click for more pic's of my S'Crew</A>2001 SuperCrew XLT 4x4 GenIII - Ordered: 2/17/2001, Received: 4/03/2001
Mods:
PIAA 520 Lights
K&N Filter
Helix Power Tower
Mods coming soon:
Stull Billet Grille
Future Mods:
SuperChip
Bed Cap
AAD F1-Hood
Dude, if youre sure you want them linked to the high beams??!!Then use any wire from highbeams, maybe in the fusebox under the hood?? BUT, most importantly use a heavy duty relay and power the lights from the battery..!! You dont want all that juice running thru your headlight switch!!
ps-how do you like the Ravins?? My Screw is just itchin for an exhaust!!
He's right, only use that source to turn on the relay. Dont' hook the lights to your OEM wiring. I'd just get into the lead to the head lamp and tap it there. Run a small wire from there to the relay, then nice big wires to the battery and lights.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Remote Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed, Keyless Entry Mod
1994 SVT Mustang Cobra. #1032 of 5009.
<A HREF="http://home.fuse.net/94cobra/my150.html" TARGET=_blank>
</A>
[This message has been edited by 2000 F150 4x4 (edited 06-23-2001).]
</A>[This message has been edited by 2000 F150 4x4 (edited 06-23-2001).]
The Piaa's come with an excellent wiring harness, including heavy wires for connecting directly to the battery, relay, and separate fuse. Everything will be wired properly, just wasn't sure where to tap in for the switch. It's recommended, and I agree, that you only have them on when the high beams are on. I'd hate to blind someone because I forgot to turn them off!
Anyway, still not positive where the best spot is... right where the headlight lamp is connected?? Fuse box?? Switch in dash??
And whichever is correct, which wire is it... brown, green, white.. I can't find a schematic anywhere!
