Accessory delay + radio mod for Screw
I just did the accessory delay + radio mod (the one where you rewire the radio power to the window power so it stays on until you open the doors) and found that for my SCrew the main wire is Yellow with a Green stripe.
The instructions are in this post:
https://www.f150online.com/f150board...ML/000400.html
These instructions talk about a grey wire with black stripe or blue wire with black stripe, but since I could not find either in my bundle, I pulled off the door switch panel and found the correct wire with a multitester.
I then followed the other instructions, and the mod works great! I like being able to turn off the engine and take my time getting out until that favorite song is over.
Since my SCrew is a Gen I, you should probably find the corresponding wire with a multi tester for your Gen II or III (in case they changed the colors again.)
2001 Supercrew XLT 4x2, 4.6, 3.55, tow pkg, moonroof, Oxford White ext. Dark graphite int, Bed Ext, ******** Decklid, Pioneer/Infinity/Rockford sound sys
