SuperCrew
My Screw is in the shop...
Old Apr 20, 2001 | 03:42 PM
RamblinWreck's Avatar
Unhappy My Screw is in the shop...
Well, I got mine back in July. It has not been to the dealer since I drove it off the lot! A friend had noticed a growl from the right front tire while riding with me, and I noticed the brakes were getting noisy. I had also become aware of the radiator issue, and my bedliner is one of the short ones that is bowing away from the sides. So, 12,417 miles later, I took her in to the shop.
Turned out it had a bad bearing & hub, and God knows what else wrong with the brakes, and the service guy acknowledged the radiator issue and agreed to replace it with a 1.47" "Y" model. However, they balked at replacing the bedliner, saying that was a sales issue. I plan to wrangle a dealer discount for a line-x job, since I don't want the liner anyway (it was already in the truck when I bought it, and they did not want to take it out, so I got it for free). Two out of three ain't bad, but I'm a little disconcerted about the bearing, since this is a 4x4. I was glad they did not put up a fight about the radiator - they said others had complained and they were swapping them out. But I have to wait until Mon or Tues for my truck since the parts did not come in. Grrrrr.....
2001 SuperCrew Lariat 4X4
Amazon green, med parchment inside,5.4L,limited slip,skid plates,C3 tow package,leather,capt chairs,6CD.
Mods: K&N air filter,SuperChip,Westin black nerfs,Fumo oil drain valve,foglight switch mod + 9005 bulbs,Catch-all mats
Soon: catback+FIPK, maybe line-x and tonneau,more later
Old Apr 20, 2001 | 04:22 PM
LightningCrew's Avatar
Unhappy
See you're a GA. boy, too. Yeah mine has been in the shop (Akins) since Tuesday. My front passenger window had a knocking sound in it when you rolled it down, the rubber flap under the front of the truck had come loose, they are checking into the radiator issue, and I had a few bad spots in the paint on the roof. No idea when I am getting it back!!! At least they gave me a loaner for free while I wait (it's not a truck, though).
2001 Supercrew Loaded
Oxford White
Lightning Front End and Wheels
Supercharger to come!!
Old Apr 20, 2001 | 09:45 PM
SCOOBY14B's Avatar
Thumbs up
RamblinWreck
I replied to your question about the MIdas dealer in my post under ON MY WAY TO ORDER.
Three Georgia boys!!!
ORDERED 4/16/01 - WOOHOO!!!
2001 F-150 Supercrew XLT 4wd. 5.4V8, 507A, 3.55LS, Captains chairs, bed extender, cab steps, power moonroof, power seat, skid plates, trlr towing, aluminum wheels, AM/FM cass with 6 cd changer. Bright red clearcoat with DARK graphite interior
IMMEDIATE MODS:
Wet Okole seat covers
Fox Weatherboots front and back
AR Baja's 16x8
Cooper A/T's 265/75/16
Tint front
Line-X
Ravin Z-55 Duals out the back
Lightening headlights, corners and tails
Old Apr 20, 2001 | 10:06 PM
Question
Scooby14B,
Have you priced out the Ravin muffler from Midas yet??
Oxford White
Old Apr 22, 2001 | 09:59 PM
tfratzke's Avatar
Angry
RamblinWreck, don't let them screw you on the bedliner. There is some serious design flaw with these Duraliner bedliners for the Screws. I am on my second one already, and now since the warm sun has been beating on it, this one is bowing out again and i've only had my truck a month! My dealer has been very good about it, and i laready informed them that about this one. I'm taking it aout and getting a Line-x...enough with this crap already.
Tony
'01 SCrew 4x4 XLT 5.4L
Old Apr 23, 2001 | 03:59 PM
Cool
Thanks for the tip Scooby, when I get my truck back I'll take it over to that Midas for my Ravin mod - I work at SA at 316 & Sugarloaf so that is very convenient.
Us Hot'lanta area screwers need to get together for a group pic to post.
RE: the bedliner - the Screw Duraliners blow. I am pulling mine out and getting Line-X job. I just have to make Ford buy my liner back to help defray the cost, and remove it for me for free.
Mods: K&N air filter,SuperChip,Westin black nerfs,Fumo oil drain valve,foglight switch mod + 9005 bulbs,Catch-all mats, Husky mud flaps
Soon: catback+FIPK or Ravin 77, line-x,more later
Old Apr 25, 2001 | 12:34 AM
Post
Got my SCrew back today. Rides smooth on the new hub and the brakes are tight 'n quiet. When I got home, I popped the hood, removed the plastic top shroud, and checked out my new fat "YL3H-GA" radiator! (Plus new coolant and I had 12k on mine nyuk, nyuk, nyuk). (I decided to wait 'n see that everything else was taken care of before I get ugly about the bedliner. Will do on Monday)
While I was at it, I did the cold airbox mod and prepped for the WMS tube which is on the way from Calgary, eh?.
Mods: SuperChip,Westin black nerfs,Fumo oil drain valve,foglight switch mod + 9005 bulbs,Catch-all mats, Husky mud flaps, airbox mods, K&N, and WMS velocity tube.
Soon: Ravin 77 w/stock pipes, Line-x, more later
Old Apr 25, 2001 | 08:32 AM
Question
RamblinWreck, Can you explain what you are doing with the "cold airbox mod"?
Gettin' my truck back today!!!!! (8 days gone)
Oxford White
Old Apr 26, 2001 | 12:47 AM
Cool
Go do a search for "air intake" in the Engines forum. Look for posts on airbox mods. Basically, I am opening up the intake upstream of the filter box where it goes into the fender. It's easy and cheap, and works. I am also removing the stock air intake and replacing with a WMS velocity tube which is just a mandrel bent pipe. Does the same as an FIPK, only is much cheaper and the engine gets cold air. You can also mod the stock intake:
https://www.f150online.com/f150board...ML/001643.html
Also check out: https://www.f150online.com/f150board...ML/000889.html
HTH
[This message has been edited by RamblinWreck (edited 04-25-2001).]
