Floor mats? Best floor mat? Suggestions?
Good question, how does the tan husky liner color match up with the supercrew tan interior? How exactly does the rear husky work.....i know its a two-piece, but does it overlap or connect somehow? Sorry 4 all these questions but i want to be completely happy with the purchase.....
<font face="Verdana, Arial" size="2">Originally posted by Leon:
Anyone have the tan flexible Husky liners? Is the color close to the Screw interior color?
</font>
</font>
From factory:
2001 White 4x4 SuperCrew (Lariat), 5.4L, limited slip, skid plates, towing pkg, captains chairs, CD changer
Add-on's:
SuperChip; Black Westin Nerf Bars; Husky Mud Guards (F&R); Beige CatchAll's (F&R); Line-X bedliner
Plans:
Cooper Discoverer STT tires; Ravin Z55 muffler; AirForce One intake
EZErriicc,
The rear floor liners do overlap. They also require some minor cutting depending on what kind of front seats you have. The instructions provided were very easy to comprehend. It only took 5 minutes to take out of the box and install it in my SCrew. As for the tan interior, the black would look better IMHO.
Husky floor mats it is....I'm going with black...Black looks good with about anything....I have captains chairs up front and gen III bench in rear, so will I need to cut them much? You don't have to chop them up to the point it doesn't look good, do you?
I didnt realize they had a mat for the front hump...Is it a one piece for the front as well or is it individuals? And if the code for the front is the same as expedition, wouldn't it mean that there are only 2 separate mats...there is a middle console on the expedition so i dont understand how they can have the same code....
I bought the Ford rubber slush mats. I work construction and track snow, mud, whatever. They fit perfect and the color matches really well with medium parchment carpet. Also they only cost $100.00 for fronts and rears.
01 Kingranch, 4x4, 5.4, Estate Green w/Arizona Beige two tone, Limited slip,Skidplates,Moonroof,Trailer tow, Cargo cage, All the Goodies!
[This message has been edited by ScrewKing (edited 04-11-2001).]
EZ- The front mats are two separate mats, one for the driver and one for the passenger. The hump mat goes over the hump and overlaps the front mats just a bit, about as much as one piece of the back mat overlaps the other. But with the two front mats, the hump mat and the set for the back, NOTHING is getting to the carpet. They cover the floor well. I go fishing at the beach a lot. I don't have to worry about the sand getting to the carpet with the husky's. The code for the hump and the rears are for the SuperCrew, the code for the fronts are for the Expy. They fit perfectly.
[This message has been edited by LouScrew (edited 04-11-2001).]
I have the Husky's in mine. Very minor trimming. They more or less have it pre-notch
as where to trim. Check it out before you cut. I did not trim quite as much as they suggested. Cuts real easy with razor blade. I have the hump liner in front. It really helps there too. Got them from cabelas in three days after ordering. The front code is for Expy. Just call them up, they will set you up right.
2001 F150 4X2 XLT SuperCrew,Arizona Beige, Gen III, 5.4L, 3.55LS, Class III Tow, Sliding Window, Black Westin's
