SuperCrew
Duraliner Installed Wrong?
Old Apr 10, 2001 | 05:23 PM
Lugnut's Avatar
Post Duraliner Installed Wrong?
Just got a Duraliner put in my new Screw. Noticed that the caps on the end of the rail covers which go over the posts next to the tailgate seem to stick up at an angle (evidently pushed up by the liner) and the middle of the liner on the back edge near the tailgate is sticking up (the back edge of the liner is arched in the middle like someone pulled up on it).
The installer said that the liner would smooth out once things warmed up. Does this sound right? Will it go back once it cools off again?
Old Apr 10, 2001 | 05:56 PM
lnavarro's Avatar
Post
On my truck, the liner is tucked under the rail cap at the tailgate edges. It is a very tight fit and does slightly push up the caps, but not a whole lot. Is it possible that yours should also be tucked under the rail cap? I know if mine was untucked the caps would push down on the liner causing the arch in the middle you describe.
2001 Supercrew XLT 4x2, 4.6, 3.55, tow pkg, moonroof, Oxford White ext. Dark graphite int, Bed Ext, ******** Decklid, Pioneer/Infinity/Rockford sound sys
Old Apr 10, 2001 | 07:26 PM
Bubbadewsky's Avatar
Talking
Lugnut----- On my duraliner (Ford) bed liner every part of the bed rail caps cover the top edge of the liner. I installed mine myself and at first had the back inside edge of the rail caps under the liner. This is incorrect the caps are supposed to be completely on top probably to help keep rain out. My tailgate piece will sometimes have a slight buckle in it when it expands in direct sunshine but when it cools off it goes back flat
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. 2.02" corrected radiator-F75Z-8005-GA --- '93 Harley Fatboy Black & tons of chrome
Old Apr 11, 2001 | 04:56 PM
FedExPilot's Avatar
Post
Lugnut;
Check this thread .... it might be helpful;
https://www.f150online.com/f150board...ML/000391.html
2001 F-150 Super Crew Lariat 4x4
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Roll-up bed cover; Six disc CD changer in '98/'99 Expedition center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX subwoofer in custom built, center console, sealed enclosure; Zapco AG150 amplifier; DRL daytime running lights with Fog Lights (Mod)available at all times;
Bel 980 Radar detector; Moon roof; Bed extender; Class 3 trailer hitch
