SuperCrew
Moon Roof Wind Noise/Deflector
Old Apr 4, 2001 | 10:26 PM
newtruckforray's Avatar
Question Moon Roof Wind Noise/Deflector
To those who have the moon roof... Do you get alot of noise when it is open? Do you have/recommend the Ford Wind Deflector accessory?
Old Apr 4, 2001 | 10:32 PM
ScrewKing's Avatar
Post
Ray, never heard of the deflector. I wouldn't own a vehicle without a moonroof. When it's open it's like having a window rolled down as far as noise is concerned. I had mine open today and it was 45 F. out. There is very little air turbulence, mostly @ the rear corners which is controlled by closing it just a little. The light that is let in is the major factor. It opens up the entire cabin. Think of your bathroom without a window and you'll understand.
01 Kingranch, 4x4, 5.4, Estate Green w/Arizona Beige two tone, Limited slip,Skidplates,Moonroof,Trailer tow, Cargo cage, All the Goodies!
Old Apr 4, 2001 | 11:03 PM
skyjet's Avatar
Thumbs up
Go to my web sight link below and I have a fix there for the viabration noise. 30 seconds and zero dollars.
<A HREF="http://www.geocities.com/skyjet1/SuperCrew.html" TARGET=_blank>
http://www.geocities.com/skyjet1/SuperCrew.html</A>
First Edition 2001 F-150 Lariat SuperCrew, Bright Red / Silver Frost, Medium Graphite Leather, 2X4, 5.4, Moonroof, 6 CD Changer, 3.55 Limited Slip, Tow package, Bright Red Lund Nose Shield, Line-X bedliner, Bed Extender, Daytime Running Lights, Magellen M330 GPS.
Old Apr 5, 2001 | 06:33 AM
Post
Thanks skyjet. Great page you have. Good page on the daytime running lights too.
Old Sep 19, 2001 | 12:26 AM
DAVEMAN's Avatar
Hey skyjet,
I checked out your site, think you could add a few more details?
Just kiddin', damn you went to a lot of effort to document all that stuff, great job. BTW, why did you spend the time to do such a detailed documentation anyway, just for the fellow F-150 owners? You sure have a generous heart!
Thanks for the extra effort, I may use some of that stuff on my '01 KR screw.
As for the moonroof question, don't have one yet so can't comment.
DaveMan
Old Sep 19, 2001 | 06:44 PM
TroyK's Avatar
check out this technical service bulletin issued by ford...
Service Bulletin Number: 14397
Bulletin Sequence Number: 620
Date of Bulletin: 0001
NHTSA Item Number: SB620433
Make: FORD TRUCK
Model: F150
Year: 2001
Component: VISUAL SYSTEMS:SUN ROOF ASSEMBLY (8/82)
Summary: CERTAIN SUPERCREWS AND SOME VEHICLES MAY EXHIBIT A WIND NOISE / BOOM WHEN DRIVEN AT HIGH SPEEDS ABOVE 55 MPH WITH THE MOON ROOF FULLY OPEN, DUE TO THE MOON ROOF WIND DEFLECTOR NOT DEPLOYED HIGH ENOUGH ABOVE THE ROOF LINE. *TT
Coming in Oct '02!
2002 4x4 King Ranch S-Crew
5.4l OHC v/8, 4R70W auto tranny
Charcoal Blue/Arizona Beige
Castano Brown Leather Buckets
Limited Slip Diff (3.55 gears)
Class III Trailor Tow
60/40 Split Bench Rear Seat
Old Sep 21, 2001 | 09:54 AM
braboin's Avatar
Question
Where do you find these TSBs? Thanks.
Old Sep 22, 2001 | 06:04 PM
nordicbastard's Avatar
I haven't noticed any Problems with wind noise.
I did have some snow dumped on the ol'noggin
showing off the moonroof.
Yes.. my first drive was in the snow !!
NordicBastard
P.S. If you drive fast enough, you won't worry about the noise !!
Old Sep 22, 2001 | 07:03 PM
TroyK's Avatar
right here on f150online...check out this link...
https://www.f150online.com/resources/tsb.html
Old Dec 19, 2008 | 10:54 PM
2000Expedition's Avatar
Sky jets link is dead so here is what worked for me
I found a way to fix the standard sun roof on my 2000 Expediton Eddie Bauer roof from the loud buffeting noise.
It will take you no more than 10 to 15 minutes, and you just need a screwdriver
Open the roof, stand on your seats, look at the spring loaded wind deflector that pops up in front of the sunroof, Unscrew the two respective phillips heads screws at the front opening that attach straps to the pop up deflector (the straps keep the deflector from popping further up).
With the two straps detached, flip the deflector all the way up and over so that is is facing the rear of the sun roof. It will now slide out of its hinges and remove it
If you lay it on the ground you will see its pretty straight, You need to get a slight bend in that deflector, so that it will arch higher than the roof line when open. I took mind and slight bent it around my stomach till I got a slight arch
Reverse the procedure to reattach.
Hopefully you tested it at 60 miles per hour before you did it, and if you arched it right, with the moon roof open the buffeting noise should be gone!
Shame on Ford for letting this problem go for 8 years and not making this simple fix common knowledge.
Old Dec 20, 2008 | 09:01 AM
NCSU_05_FX4's Avatar
Originally Posted by 2000Expedition
Sky jets link is dead...
After more than 7 years, I'm not surprised!
Good tip, but on my 2005, I don't really have much noise associated with the moon roof. If I do, I'll just crack the rear sliding glass and it solves any issues.
- NCSU
Old Dec 20, 2008 | 11:12 AM
welfare wagon's Avatar
Bought mine Ebay a few years back.
Seller still has some.
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
