SuperCrew
Vibration
Old Feb 16, 2001 | 08:08 AM
sprcrew's Avatar
Post Vibration
Just picked-up my new Screw this week and I'm getting a severe vibration (buzz) in the steering wheel at speeds above 65. The vibration seems cyclical in nature.
I did a search on vibration and didn't get much back.
I'm going to take it back to the dealer, but I just wanted to see if this is a common problem that I should be concerned about.
I'm a GM convert and I'm not familiar with Fords *common* problems...
TIA!
Old Feb 16, 2001 | 10:20 AM
Dewayne Fuller's Avatar
Post
None on mine or the other three at work. Let the dealer check it out. It could be a bad tire or balance. Congrats on the new SCrew.
Mine:2001 1/2 F150 Super Crew, Lariat, Oxford white w/silver lower accent and Med. Gray Leather Captain Chairs,4x4 ORP, 5.4L, 3.55LS, 17" Chrome wheels w/GY AT/S LT265/70/17, auto, 6 CD,Towing package, alarm, Westin Chrome nerf bars, Seat Savers and Husky mats for hunting, bed liner, white tail light lens covers.
http://albums.photopoint.com/j/Album...1294&a=3025874
Wife: 1999 Explorer Limited,pearl white/tan leather,4.0L,4:10LS,CD,sunroof,towing pkg.,alarm. Bought new Sept. 1999
Previous: '65 Mustang 289 HiPo, '70 Chevelle SS 396, '70 Vette Conv. 350/350, 72 Datsun PU,'74 Vette TTop, '79 Blazer, '81 F150, '83 Bonneville, '84 Gran Marquis '89 TBird Super Coupe 3.8L SuperCharged, '93 Explorer 4.0L, '97 F150 SC XLT, 4x4 ORP
Old Feb 16, 2001 | 08:51 PM
Mikee's Avatar
Post
I picked mine up with only 11 miles on it. It was only driven from the railyard to the dealership. I have the damn 17" Goodyear RTS's. Apparently the tires were in balance but "out of round" on the rims. I had my local tire shop take each tire off the rim at least twice and turn to locate the "smooth spot" of the tire. Well this fixed three of the tires but the fourth had to be replaced under warranty. My other problem was that the truck was wandering on the interstate. I had the front end checked and it was dead in alignment. I finally figured out the wandering was due to too low tire pressure. I put in 38 psi and the wandering is not nearly as bad. The dealership should fix your tires but make sure they go the "extra mile" and pull each tire with the problems off each rim until they can smooth it out.
<font face="Verdana, Arial" size="2">Originally posted by sprcrew:
TIA!
</font>
[This message has been edited by Mikee (edited 02-16-2001).]
Old Feb 17, 2001 | 02:05 PM
1stnuford's Avatar
Post
&gt;&gt;MIKEE&lt;&lt; , I have the same problem with the wandering front end. But, it's not the tires. I have played with air pressure to no avail. Then visited the best front end shop. They found the idler arm and pitman arm to have movement. Has been to dealer 6 times. Replaced idler arm, pitman arm and steering box. No luck. Waiting on new idler arm again. But I'm not optimistic. If there were aftermarket parts availabe, I'd fix it myself. If you jack up one side of the front at a time, check the wheel. I'll bet you can wobble it around. Then check the other side and you will find the same. Now put both of those movements together and the truck can't drive straight without wandering !! After 17000 miles, the tires tell the tale. I'm still waiting on a fix..
2001 SCREW;OX-WHITE/SILVER;5.4L;4X4;Skid plates;Limited- slip;Char-gray interior w/bench seat;Tow Pkg;17"Wrangler RTS With 10 Spoke Alum whls;CD;Slider Rear;NO DECALS/PIN STRIPES;Super-Chip;K&N filter.
Old Feb 17, 2001 | 11:09 PM
Mikee's Avatar
Post
I had my front end shop check the front tires for any movement. They could not find any play. Do you think that it is perhaps the damn terrible Goodyear tires?
<font face="Verdana, Arial" size="2">Originally posted by 1stnuford:
</font>
Old Apr 3, 2001 | 11:38 AM
geb's Avatar
geb
Post
can you explain what you mean by smoth spot?
I have a new Screw with 12 miles that vibrates!
G
4X4 SCREW-Arizona Biege-5.4,L.S., Moon Roof, Leather Bench, Skid Plates, Rear Slider, Bed Extender, 6 CD changer, Towing Group III-
*Build Date 3-19-01
Old Apr 3, 2001 | 02:39 PM
sprcrew's Avatar
Cool
I cured my vibration by running 38lbs in the tires and by backing out a 1/2 turn on the steering box. The air pressure change really helped (as mentioned by others...)but the gearbox adjustment made the steering wheel dead smooth. I can't figure the air pressure deal as the increased pressure should have made any vibrations even more noticeable. I dunno...
Lariat,4x2,5.4L,60/40 bench,cd-changer
Old Apr 4, 2001 | 11:11 AM
XTRUKY's Avatar
Post
Don't know if it means anything, but I have a 2WD SCrew with BF goodrich tires and have NO wandering what so ever.
I have never had any luck with Goodyear factory tires. I thank GOD mine came with BFG's
2001 Lariat SCrew / Oxford White / Sunset Orange Pearl (House of Kolor)
Truck Master Designs FD630-S AirDam, Gibson 9504/Split Rear Exhaust, Fac Moon Roof, 3:55LS, 6CD, Gen III/Beige Buckets, Cab Steps, Slider, Tow, Bed Extender, Bell Tech 2" Shackles, Snug Lid
Check out my Photo's at
http://photos.yahoo.com/bc/xtruky
Old Apr 4, 2001 | 01:33 PM
StrongWind's Avatar
Post
I've got the BFG TA's on mine and have no problem. Smooth, quiet, decent grip in the wet. My past experiences with Goodyear tires has not been good. I would trade/sell/get rid of any Goodyear tires on any vehicle I own. I've experienced tires that took excessive weight to balance (yes, the rims were straight) to tires that were so out of round they had to be trashed. Try Michelins or the BFG's that are coming on the new Lariats. I've been very happy with both.
2001 F150 Supercrew 4X2 (Gen III), Lariat, Arizona Beige Metallic, 5.4L, Towing Package, 3.55 LSD, Moonroof, Captains Chairs, Premium Sound, Extender
Ordered 14 Dec 2000, Received 9 Feb 2001 Life is Good...
Modifications:
Line X bedliner, Ford factory splashguards, Black Westin Step Bars, Aux Back Up Lights, Advance Cover folding hard cover
