SuperCrew
bedrug plays nice with bed extender?
Old Mar 1, 2001 | 12:43 AM
pesos's Avatar
Post bedrug plays nice with bed extender?
well the truck is going to be here any day now... and i ordered a bedrug from the local shop for $387 installed... I'm curious as to how it works with the bed extender... are there holes that need to be cut in the bedrug to accomodate it? don't want to screw it up.
thanks,
Wes
SCrew Lariat 4x4, 5.4L, Lim. Slip, Black Ext./Graphite Int., Tow Pckg., 60/40 bench, Moonroof, Bed Extender, Cab Steps, Rear Window
Ordered: 1/12/01
Shipped: 2/21/01
MODS: Airforce 1 FIPK, Gibson Sweptside Exhaust, Bedrug, Husky liners, 2001 Lightning taillights
Old Mar 1, 2001 | 06:28 AM
Tim56Ford's Avatar
Post
The bedrug as the holes marked on the back side but have not been punched all the way through. I went ahead and took my tie down hooks off and then found the holes by using an awl and made a small hole for the bolts. You should be able to do the same for the bolts of your extendar and the holes should be easy to mark.
Good Luck,
Tim
Old Mar 1, 2001 | 11:30 AM
pesos's Avatar
Post
great, thanks tim! I'm assuming if I make the holes small enough, it won't cause any leaks?
do you ever get water under the rug? either through holes or just from it sneaking under the rim of the bed? if so does it dry out pretty quick?
any other bedrug issues I should be aware of?
thanks,
Wes
Old Mar 2, 2001 | 12:44 AM
ajadatz1's Avatar
Post
pesos...
I came across this write-up the other day. It may help you...
http://www.4x4review.com/cool-prod/bedrug.asp
Ordered: 01/19/01
Build date: 02/26/01
ETA on delivery: 03/19/01
2001 XLT SuperCrew
DarkHighland Green
5.4L
3.55 L/S
Towing package
4x4 package
17" Alum Wheels
Sliding Rear Window
Cap chairs
Awesome truck!!!!!
