SuperCrew
automatic door locks
Old Dec 29, 2000 | 08:12 PM
anteater's Avatar
Thumbs up
OK, Here is the instructions, but you had better read through them the first time, then try to do it!
Deactivating/activating the autolock feature
You must complete steps 1-7 within 30 secs. or the procedure will have to be repeated. If the proceedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key ON
2. Press the power door unlock control three (3) times
3. Turn the ignition key from ON to OFF
4. Press the power door unlock control three (3) times
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once if the autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the proceedure is complete.
Good Luck!
Old Dec 30, 2000 | 12:12 AM
dmkraft's Avatar
Question automatic door locks
I have misplaced my owners manual. I would appreciate it if someone could post the instructions for disabling the automatic door locks. Thanks.
2001 Supercrew, Red/Gold, 5.4, 4X4, 3.55 LS,slider, 17" wheels, cab steps, cd changer, gibson catback, k&n, pendaliner.
Old Dec 30, 2000 | 02:28 PM
dmkraft's Avatar
Post
