SuperCrew
Bed Extender Security
Old Oct 10, 2000 | 08:35 PM
CASUPERCREW's Avatar
Post Bed Extender Security
Here is what I did to keep my Bed Extender mine!
<A HREF="http://www.geocities.com/casupercrew/thumbs.html" TARGET=_blank> </A>
<A HREF="http://www.geocities.com/casupercrew" TARGET=_blank> </A>
2001 Supercrew 4x4 XLT Harvest Gold, 5.4L, Bed Extender, 6 disc CD changer, Limited Slip, Keyless Entry...
MODS: K&N filter, Trenz billet grille, Rhino Bed Liner...
[This message has been edited by CASUPERCREW (edited 12-17-2000).]
Old Oct 10, 2000 | 09:32 PM
Femseadoo's Avatar
Post
Would you be able to offer an explanation as to what you did? The Pics came out very large, and it looked like there was an extra piece on there, but how does it prevent cage theft?
Thanks.
Old Oct 10, 2000 | 10:20 PM
crewchief's Avatar
Post
It appears that the added "leg" would prevent the cargo cage from being pushed downward to remove it from it's pivot studs, providing the cage is inside and the tailgate is locked.
2001 Supercrew XLT 4x4.
Superchipped 5.4L, 3:55ls, tow package, heavy-duty electrical and cooling, skid plates, 17" 10 spoke wheels, remote keyless entry, cabin air-filtration kit, moonroof, bed extender, "Ford" rubber bed mat, rear slider, dark graphite int. and bright red exterior, SnugLid hard tonneau.
mysupercrew.com
Old Oct 11, 2000 | 10:15 AM
Post
crewchief is correct.
I drilled a hole in the bed extender and used a 3" carriage bolt, aluminum spacer and attached the bolt using a threaded rubber bumper on each side of the extender. The bolt almost hits the bed so the hardware can not be unfastened when the extender is in the closed position.
Old Dec 10, 2000 | 02:56 PM
woody24's Avatar
Post
Hey guys I remembered this from the archives. Thought someone would be interested.
Old Dec 10, 2000 | 06:41 PM
FyrDawg2's Avatar
Thumbs up
Here's my fix for locking the unit in place whether it's folded away with the tailgate closed and locked OR in use with the tailgate open....
Old Dec 10, 2000 | 06:48 PM
FyrDawg2's Avatar
Thumbs up
Drill a hole on each side so that when the shackle is inserted, it prohibits the 'spring latch' from being depressed!
[This message has been edited by FyrDawg2 (edited 12-10-2000).]
Old Dec 12, 2000 | 06:16 PM
kwthunb's Avatar
Thumbs up
Harvest Gold Lariat Screw w/ SuperChipped 5.4L, 4X4 package, towing package, captain's chairs, moonie, slider, 6cds, Westin grill, Explorer driving lights, Husky floor liners, DashMat, DuraLiner and Bed Xtender.
Got my Bed Xtender aftermarket (less than $200) and installed it myself. After reading these posts I checked mine for security. The opening on the bracket faces up on my model but the plastic fitting is designed so that the Xtender cannot be removed while the tailgate is up. Fortunately, it also locks on the Screws!
Old Dec 13, 2000 | 02:14 PM
brossman's Avatar
Question
kwthunb,
What brand is your aftermarket Xtender and are you happy with it?
Craig Brossman
Ordered 2001 SCrew 4WD Lariat (12/05/00)
Az Beige/Wedgewood Blue
Cpts. chairs, Moon roof, Tow package, CD changer
3.55 lim. slip, Rear slider, Skid plates
Status: Clean/Unscheduled
Old Dec 13, 2000 | 03:30 PM
2001's Avatar
Question
Ya...KWTHUNB what kind of aftermarket extender did you get???
We need to know!
Old Dec 14, 2000 | 07:06 AM
jimmy's Avatar
Lightbulb
search this forum on
'bed x-tender' and 'bed extender'
Old Dec 15, 2000 | 12:33 AM
kwthunb's Avatar
Post
Sorry, it was the "Bed Xtender" offered in Cabela's catalog. I bought the *full sized* model and had to cut off about six inches from each tube to make it fit. The cutting is anticipated in the instructions.
Old Dec 16, 2000 | 10:01 PM
skyjet's Avatar
Post
CASUPERCREW,
What is the diameter of the carriage bolt and can you get the spacer and the threaded bumper at a Home Depot type of place? How long is the spacer?
Thanks www.over.to/SuperCrew
2001 F-150 Lariat SuperCrew, Bright Red / Silver Frost, Medium Graphite Leather, 2X4, 5.4, Moonroof, 6 CD Changer, 3.55 Limited Slip, Tow package, Bright Red Lund Nose Shield, Line-X bedliner, Bed Extender.
[This message has been edited by skyjet (edited 12-16-2000).]
Old Dec 19, 2000 | 12:04 AM
Post
Skyjet,
I forgot to mention previously that this set-up is in both sides of the extender.
The carriage bolt is 4" L x 3/16" D. (I changed out the 3", you may have to cut the 4" a little so the extender folds smoothly.
The spacer is 1-1/4" long.
The threaded bumper can be purchased at your local hardware store. I got mine at ACE Hardware. The aluminum spacer may be a problem. Mine were left over from an air filter kit for my Harley. I would have probably used a piece of pipe and a washer in lieu of the spacer.
Old Dec 21, 2000 | 08:03 PM
keeper15's Avatar
Post
hey casupercrew...pacifica is a nice place
real close to montara...got a problem...bought a ford bed extender from ebay...got the bolts that screw into the sides of truck bed for extender to sit snugly
but there are no threads in hole ...what am i missing in my truck bed to install these bolts...any one have an idea on this one....thanks
2001 lariat supercrew
black...factory running boards/moonroof/k&n filter/duraliner/leer top/sheepskins/
future mods...
superchip/exhaust?/clear corners/WMS intake/
