SuperCrew
Front Doors Hard To Open
Old Jun 7, 2000 | 12:14 AM
SHEGAMEN's Avatar
Question Front Doors Hard To Open
It seems you have to pull the door open after you release the handle. It doesn"t seem right.
My first nex gen f150 is this normal??
both drivers & pass. side
Old Jun 7, 2000 | 11:40 AM
SurfinCowboy's Avatar
Post
The front doors should pop right open when you lift the handle. I looked at several before buying mine, and they all "popped" open. Have them check the alignment with the door lock hinge. Also look around for metal shavings, scrape marks or black paint missing from the lock post and mechanism. That should tell you it's not aligned properly. Most of the door lock parts and hinges are painted black if i am not mistaken. I have been in and out of my truck so many times, and I have yet to see any of the door parts with missing black paint, scratches, etc.
The doors I am having problems with are the rear doors!!! Having a hard time keeping them OPEN. They always fall back on me when I am parked on the driveway-Dern that hurts !!
White,XLT 4x4,5.4L,K&N Filter,....what's next?
Old Jun 8, 2000 | 12:22 AM
rmarietta's Avatar
Post
SHEGAMEN,
Check out your local dealer and pull a few doors!
Old Jun 30, 2000 | 07:26 PM
waltesa's Avatar
Post
Shegamen:
I have the same problem w/ my driver's door. Whowed it to the salesman, and he found the problem - the bracket on the frame which the door latches onto when closed is slightly out of alignment. he didn't think that it could be fixed, but I'll asked the garage when it goes in for its first oil change.
Old Jun 30, 2000 | 08:01 PM
woody24's Avatar
Post
My driverside rear door does the samething. There are no scrapes or scratches. After you pull the latch, you have to give it a tug to open.
Old Dec 19, 2000 | 10:11 PM
rjhuss's Avatar
Question
I know this is a old issue, but did we ever get a solution for it. I am taking my GEN1 SCREW into the dealer this week for a oil change and my driver-side rear door is hard to open.
Did anyone get this problem fixed?
Old Dec 20, 2000 | 05:39 PM
cavecrew's Avatar
Post
I'm having the opposite problem. My passenger side door want shut completely. You have to really slam it to get it to close.
Old Dec 21, 2000 | 06:59 AM
arbee's Avatar
Post
I am with cavecrew on this one. I haven't noticed anything with opening the doors but the front passenger door is much harder to close than the drivers.
