Extang Cargo Cleats
I purchased two pair of the Extang Cargo Cleats for my SCrew. Due to the bed rail cap, they did not fit. Extang had not heard that there was a problem; they know now. They tried to make one fit, and agreed that it will not. Extang's suggested solution was to remove the bed rail caps. **NOT** a happening thing!
I drilled two holes in the cargo cleats below the reinforced bolt holes, and installed them. They are a bit ugly, as the inside piece hangs down too low and at an angle, but they are solid, and will work until Extang comes up with a better solution.
They should be a useful accessory, as the nautical cleat is much simpler to deal with than tying knots in the stock tie-downs in the bed. Just be aware that they do not fit in the SCrew in their stock configuration with the bed rail caps attached.
Tom Brendel
2001 SCrew XLT 2WD, Toreador Red, 5.4L, Med. Parchment 60/40, 3.55 LS, Class III Towing Pkg, Aluminum Wheels, CD Changer, Bed Extender
Mods: K&N Air Filter, Superchip, Extang Black Max Soft Toneau Cover, Extang Cargo Cleats
Tom Brendel
