SuperCrew
Wind noise
Old Oct 26, 2009 | 08:48 PM
Moragin's Avatar
Wind noise
I think I have leaves and things trapped in the washout under the windshield wiper blades. Not really much of mechanic but is it much of a job to get that plastic grilling off under the blades to get in there and clean things out. For a while I thought it was the under hood liner vibrating at speed so I re-glued the edges with silicon but hat was not the problem. the washout gutter seems more likely.
2006 FX4 s' crew.
Old Oct 27, 2009 | 10:46 AM
PartsChaser's Avatar
Its not hard to get that cowl cover off.. there is a little plastic plug on each side, then you can just pry it off. Just be careful not to break any of the little tabs, they are a pain to re-install if you accidentally tweek it
