SuperCrew
3.55 ls
Old Oct 14, 2009 | 02:25 AM
supercrewguy's Avatar
3.55 ls
i have a 3.55 open rear diff and i was wondering if there was a 3.55 ls you can buy
Old Oct 14, 2009 | 06:37 AM
Norm's Avatar
Check your axle code on the tag or between the drivers side doors. Most 01 and 02 screws were LS.
Old Oct 14, 2009 | 09:25 AM
06 So Comfort's Avatar
If, indeed, you have an open rear differential, then yes, you can buy a Ford Trac Loc and have it converted. The labor charge shouldn't be much more than an hour to install the new clutch pack and spyder gear (assuming you do not have to rebuild the rear).
Old Oct 15, 2009 | 09:48 PM
hey thanks for the help guys i really appreciate it
Old Oct 16, 2009 | 03:10 PM
APT's Avatar
APT
Regardless of if you have the OEM LSD, the clutches are probably worn out. Going to a locker isn't a bad idea.
Old Oct 25, 2009 | 11:02 AM
Alex5's Avatar
is a rebuild kit available?? if so what's the cost on the kit? thanks
