Gromets For Coax Cable
Gromets For Coax Cable ** UPDATED **
Anyone have a layout of the gromet locations for the 2005 Screw? I need to run some Ham radio antenna coax into the back of the cab. The coax will have PL259 connectors on it so tiny holes wont work.
Thanks.
** UPDATE ** for helping those that might need the info.
I removed the rear seatback, WHAT A PITA THAT WAS! If you pull back the liner against the back wall in the lower corner there are rectangular plastic inserts on both sides. These are openings leading to the outside of the rear of the cab with what feels like a rubber flap on the outside. I think this would be ideal to run any kind of cableing to the outside of the cab. The holes in the plastic inserts are large enough to pass thru PL259 connectors for Ham or CB radios. I post som pictures if I can. I have no idea what these plastics inserts are for but read somewhere they are for releasing pressure when shutting the doors.
Thanks.
