SuperCrew
Where is it?
Old Mar 23, 2009 | 08:29 AM
DennyCrane's Avatar
Question 140°F ??? Can't be ok?!?
Hi everybody...
Can somebody tell me where the sensor for the temperature is?
My truck always shows me it's 140°F out there..
I'm pretty sure I'm not in hell (yet ) maybe I can fix the sensor myself or at least get myself a new one
Thx for any help
Bye Max aka DennyCrane
Old Mar 24, 2009 | 09:16 PM
greencrew's Avatar
I replaced one on my 01, and it was just behind the grill. I'm not sure about the 05?
Old Mar 24, 2009 | 10:26 PM
cstanek's Avatar
It's mounted on a beam between the grill and the radiator. If you pop the hood, you'll see two sensors. You want the one without the bar code - I think that one's for the airbag.
I had a similar problem with my thermometer. I just took off the sensor, cleaned up the connections, put it back on, and have had no problems since.
Old Mar 25, 2009 | 02:21 PM
DennyCrane's Avatar
Perfect! Thank you very much.. I'll try it tomorrow and let you know if it worked.
Thank you very, very much... It's so stupid to see the 140°F outside-temp. the hole time
Old Mar 27, 2009 | 11:59 AM
DennyCrane's Avatar
Problem solved
Hi ...
Ok I found the sensor and cleaned it.. Sad but true - NOTHING HAPPEND!
I went to my local Ford-Dealer an got a new one.. Problem solved..
Just for others if you need to now how this thing looks like...
Here it is:
