Slight Hesitation When Accelerating
Hi,
My 2001 SC has 43,000 miles. I notice that when I press on the accelerator now, there’s a slight delay in response that I can feel from my foot to the rear axle. Could someone give me an idea on where to first diagnose the problem before I either repair it or take it in?
Thanks,
Jon
Thanks,
Jon
Fuel Filter.
I just replaced mine 2 days ago, and I have a brand new truck. I wasn't able to spin the 33's I have over. Now, I have to be easy on dry pavement.
If you have had that done recently, you may want to check driveline play. Including, but not limited to, drive shaft and u-joints. There are other peices to that, but I don't want to mis lead you.
let use know how it works out?? i seem to have the same problem. i have a 2002 f150 Screw 4x4
Look on the inside of the frame right under the drivers side door. It requires a special tool that will cost you about $10 at a parts store.
Here is a link to a thread in our "How to" section. I believe your 2001 would be pretty much the same.
https://www.f150online.com/forums/ar...r-install.html
Bluejay.. thanks for the links. I took it to PB. It turned out to be low transmission fluid. They gave me the option of power flushing the trans but I decided to wait 'till my tax check came in and do a "works" package (including f.filter).
Thanks again,
Jon
Thanks again,
Jon
