SuperCrew
biggest tires on stock 01 4x4?
Old Dec 9, 2008 | 10:30 AM
fatscew's Avatar
what is the biggest tires i can fit on my stock wheels at stock height?
Old Dec 11, 2008 | 08:16 PM
fatscew's Avatar
no one????
Old Dec 11, 2008 | 10:06 PM
wandell's Avatar
You can fit up to a 35x12.50 by using the oem wheels. However, this is an extremely tigh t fit and they will rub the frame at full steering lock. I would stick with 33's unless you plan on lifting the truck in the near future.
Old Dec 13, 2008 | 09:59 PM
fatscew's Avatar
do you think i could clear 34-10.50 with my oem wheels with no lift???
Old Dec 14, 2008 | 10:36 AM
sixpack1's Avatar
Why don't you put a set of 30" or 285's and get full range of motion on the fronts without any rubbing anywhere. Thats a big enough tire to look good on a unlifted truck. You could also get a front end leveling kit on ebay fairly cheap or crank up the torsion bars to improve the overall stance.
Old Dec 14, 2008 | 11:26 AM
firstimeFord's Avatar
I was looking into this a few weeks ago. Without cranking the torsion bars, the safest bet is 285/70/17. With torsion bar lift, 295's. There is still a chance of rubbing fronts when wheels turned and frontend compressed.
I ended up with 275/70/17. Just a little bigger than stock but looks much better. My biggest fear was loss of power and mpg since I only have 3.55's. I can definitely tell the difference with the taller tire and I'm glad I didn't go any bigger.
Old Dec 14, 2008 | 11:38 AM
redneckhunter24's Avatar
I have 33x12.50 mickey thompson baja claws on my stock 01 4x4 supercrew. No rubbing at all and they fill up the wheel wells real nice. Definitely gave the truck a good tough look. I have 3.55ls gears too and didnt notice any power loss. Gas milage went down a little bit tho
Old Dec 14, 2008 | 10:07 PM
wandell's Avatar
Yes.
Old Dec 15, 2008 | 05:43 PM
4wd150's Avatar
yeah i think a 285 or 305/65 will look good. i have the 305s and previously ran 285s. both worked great
Old Dec 24, 2008 | 02:35 PM
fatscew's Avatar
thanks guys...i think im gunna go with a 33-12.50 on my stock wheels...i have the 3/55 gears also and the only mod i have is true daul straits with all of the cats...i should'nt loose any power should i?
Old Dec 24, 2008 | 10:32 PM
wandell's Avatar
No, not much.
Old Jan 6, 2009 | 06:32 PM
m.erickson's Avatar
Smile tire size
the biggest i have seen is 31X10.5 you might have to drop a wheel size to make them fit right. or you could do a cheap lift and go bigger.
Old Jan 6, 2009 | 07:06 PM
minimonster17's Avatar
the biggest i would go w/ a stock stance is a 305-70-17, and cranking the torsion bars. if you don't want to crank them, i would stick w/ a 285-70-17.
Old Jan 6, 2009 | 09:46 PM
wandell's Avatar
Really? Most 97-03 F-150 4x4's came stock with 265/70-17 tires which are essentially a 32x10.50.
