SuperCrew
2001 Super Crew replacement rockers?
Old Oct 28, 2008 | 05:30 PM
2001SUPERCREW's Avatar
Does any one know were to get replacement rockers for a 2001 Super Crew?
thanks,
Old Oct 31, 2008 | 07:05 AM
1bad86vmax's Avatar
thanks,
Are you aware the rockers on these trucks span all the way up to the roof . To purchase new rockers from a dealer , then have installed and painted , you would be looking at roughly $3000.00 per side . Or you could do what I done . Cut out the metal on the bottom side of the rocker that is rusted . I think about 4" wide x 75" long . Weld in new metal , grind smooth , bondo with duraglass and then paint . Total cost was around $400.00 for both sides . If you don't fix it now , it will continue to get much worse .
