TSB Info
TSB Info
Just wondering if somebody has any additinal info on the following TSB's??
22520 SUSPENSION:REAR:AXLE:NON-POWERED AXLE ASSEMBLY
Bulletin No: 061916
Date of Bulletin: 03/19/2007
Summary Description:
SHUDDER/VIBRATION ON MODERATE TO HARD ACCELERATION. *KB
AND
03000 POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin No: 06227
Date of Bulletin: 12/20/2006
UN-COMMANDED TCC APPLY ON THE 1-2 SHIFT CAUSING PERCEPTION OF HESITATION AND/OR LACK OF POWER DURING SHIFT. *KB
Jeff
Bulletin No: 061916
AND
Bulletin No: 06227
Jeff
Is this the first one updated:
06-19-16 SHUDDER/VIBRATION ON MODERATE TO HARD ACCELERATION
Publication Date: September 19, 2006
FORD: 2004-2007 F-150
LINCOLN: 2006-2007 Mark LT
This article supersedes TSB 06-11-3 to update the vehicle model years.
ISSUE:
Some 2004-2007 F-150 and 2006-2007 Mark LT vehicles may exhibit shudder/vibration on moderate to hard acceleration.
ACTION:
Adjust the rear axle pinion angle. Order and install the appropriate shim kit for 4X2 / 4X4 Light Duty or 4X2 / 4X4 Heavy Duty vehicle. Refer to the Driveline Angle Corrections chart in this TSB. Refer to the installation Instruction Sheet included in the kit.
NOTE: FOR 2-PIECE DRIVE SHAFT EQUIPPED VEHICLES IT MAY BE NECESSARY TO ORDER THE FOLLOWING ADDITIONAL PARTS:
EOTZ-4A209-A - Center Support Shim (Up to 3 maximum)
W711116-S439 - Center Support Mount Bolts
NOTE: HEAVY DUTY REAR AXLES HAVE 7 LUG NUTS.
PART NUMBER PART NAME
4L3Z-4C088-AA Shim Kit - Light Duty 4X2
4L3Z-4C088-BA Shim Kit - Light Duty 4X4
4L3Z-4C088-CA Shim Kit - Heavy Duty 4X2
4L3Z-4C088-DA Shim Kit - Heavy Duty 4X4
EOTZ-4A209-A Center Support Shim
W711116-S439 Center Support Mount Bolts
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
061916A 2004-2007 F-150 And 2006-2007 Mark LT: Road Test, Install Wedge, Road Test, Install Wedge, Road Test (Covers Procedure A, B, C, Or D) (Do Not Use With 1007D, 4200B) 2.7 Hrs.
061916B 2004-2007 F-150 And 2006-2007 Mark LT: Road Test, Install Wedge, Road Test, Lower Center Bearing By Adding 1/4 Inch Shims (Install Shim, Road Test, Install Shim, Road Test, Install Shim Road Test) (Covers Procedure C/C1, D/D1) (Do Not Use With 1007D, 4200B) 3.2 Hrs.
061916C 2004-2007 F-150 And 2006-2007 Mark LT: Road Test, Adjust The Center Bearing By Installing 2 Shims, Road Test, Remove Shim Road Test, Remove Shim Road Test, Install Wedge, Road Test (Covers Procedure E) (Do Not Use With 1007D, 4200B) 3.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
5793 42
ISSUE:
ACTION:
WARRANTY STATUS:
DEALER CODING
5793 42
Second one:
FORD: 2005-2006 Crown Victoria, E-150, E-250, Expedition, F-150
LINCOLN: 2005-2006 Town Car
2006 Mark LT
MERCURY: 2005-2006 Grand Marquis
This article supersedes TSB 06-8-2 to update the Service Procedure and add Service Labor Times.
ISSUE:
Some 2005-2006 vehicles with a 4R70/75E-W may experience an un-commanded torque converter clutch (TCC) apply or TCC partial apply immediately after the 1-2 shift. This may result in the perception that the vehicle lacks power or that the transmission is up-shifting too early. No DTCs are set during this condition.
ACTION:
Follow the Service Procedure for verification and repair.
SERVICE PROCEDURE
Monitor (TCC %) solenoid command state - duty cycle and (TC SLIP ACT) torque converter clutch slippage - RPM, while in 2nd, 3rd or 4th gear with a TCC % reading 0.
If TCC % = 0 and TC SLIP ACT = less than 20 RPM then inspect the number 7 check ball (Figure 1) in the main control valve body for damage. Replace as required following the appropriate Workshop Manual (WSM) under Disassembly and Assembly of Subassemblies - Main Control Valve Body.
NOTE: THIS PROCEDURE IS PERFORMED IN 2ND GEAR AUTO (NOT MANUAL 2) MONITOR (TC SLIP ACT) AFTER THE POWERTRAIN CONTROL MODULE (PCM) COMMANDS 2ND GEAR AND BEFORE THE VSS READS 35 MPH (56 KM/H).
If you receive any other reading, this TSB does not apply and follow normal diagnostic procedures as outlined in the appropriate WSM.
NOTE: IT IS NORMAL FOR THE PCM TO COMMAND 4TH GEAR AT SPEEDS AS LOW AS 19 MPH ( 30 KM/H) WITH LIGHT ACCELERATION WHEN THE THROTTLE POSITION IS LESS THEN 20%.
EOAZ-7E195-B Ball Check
1L3Z-7C155-AA Gasket - Valve Body Upper
1W7Z-7D100-AB Gasket - Valve Body Lower
XT-5-QM MERCONŽ V Automatic Transmission Fluid
WARRANTY STATUS:
062207A 2005-2006 Crown Victoria/Grand Marquis/Town Car/Econoline/Expedition: Includes Time To Inspect, Diagnose, And Repair (Do Not Use With 12650D, 12650D45, 12650DX1, 12650D81, 7191A, 7191A1, 7000A13, 7191A2) 2.3 Hrs.
062207A 2005-2006 F-150/MarkLT: Includes Time To Inspect, Diagnose, And Repair (Do Not Use With 12650D, 12650D45, 12650D81, 12650DX1, 7191A, 7191A1, 7000A13, 7191A2) 2.2 Hrs.
DEALER CODING
7E195 01
2006 Mark LT
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
7E195 01
