SuperCrew
factory Alarm or remote start??
Old Jun 20, 2007 | 07:20 PM
Zorro_sn's Avatar
So i thought I read somewhere that there was a factory alarm and remote start for my 06 lariat screw. From calling the dealer, they say no. That they have it installed from someone else, and the alarm/remote start is "Omega" brand.
Does this ring a bell to anyone? I really wanted to get a factory brain/module to have a clean install and not another remote to carry/switch from
Old Jun 21, 2007 | 02:09 AM
sidthafish's Avatar
I know factory remote start will be an option for 08' but as of now, no. I think you're stuck with aftermarket for now.
Old Jun 21, 2007 | 03:01 AM
memLT-1's Avatar
Ford sells a remote starter and alarm system. Also has a warranty thats is the same as your truck 3-36. I beleive it comes in 3 stages bronze silver gold.Bbonze is a keyless entry, silver is keyless entry and remote start, gold is keyless entry remote start and alarm. The silver & gold comes with its own remote that replaces the factory one and operates everything.They should have a broshure in the parts dept. showing this and other dealer installed options.
Old Jun 21, 2007 | 07:51 AM
dennisfranz's Avatar
I believe those are Code-Alarm units. IF you would not mind installing yourself and saving a few bucks, KC Autosound has a package with wiring info specifically for the F150's.
Old Jun 21, 2007 | 08:36 PM
Zorro_sn's Avatar
how difficult is the install? Is it simple to keep it clean under the dash?
Old Jun 24, 2007 | 12:15 AM
Gearhead99's Avatar
I have installed the Ford remote start system in my 2007 HD F150 pick up. It works great.
It is made by Code Alarm.
Old Jun 24, 2007 | 03:14 AM
Ken07Harley's Avatar
Did you do the install yourself? Or did the dealer install? Do you know if it's fairly simple mod or requires a lot of wire splicing and such?
Old Jun 24, 2007 | 11:39 PM
DirtyDoggT's Avatar
I agree. Hit Travis up at KC Autosound. He has quite a few systems to offer with his pre-wiring. When I say pre-wired it means that he has prepaired your system for you to install it by getting rid of unnecessary wires. He then tapes the harnesses in a way that you will be routing them to the proper locations. He then gives you a step-by-step installation guide with pictures that tells you what wires to go to and what they read on a meter or test light. On top of that he's just a phone call away for tech help that is included with anything he sells.
