SuperCrew
gear size (inches)
Old Jan 16, 2007 | 10:53 PM
bassmaster1061's Avatar
gear size (inches)
are the gears for my truck 8.8"? Would these be the right ones:
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Jan 17, 2007 | 01:30 AM
bigtruck311's Avatar
since you have the 5.4 you 99% of the time will have a 9.75 in the rear, so these gears will not work for you check and make sure but i am pretty sure you have a 9.75 rear, look under your truck if it kinda looks like a stop sign shape than you have the 9.75 if it is round then you have the 8.8.
Old Jan 17, 2007 | 02:03 AM
cpaggie_07's Avatar
I thought all F150s had an 8.8" rear differential. Am I mistaken?
Old Jan 17, 2007 | 09:00 AM
APT's Avatar
APT
4.6L get 8.8" and 5.4L get 9.75" except the 7700 payload package that got 10.25" axle.
Old Jan 17, 2007 | 09:38 AM
cpaggie_07's Avatar
No kidding? Why'd Ford do that? I though the 9.75" axle was a heavy duty thing, like on the Super Duties. Is the 9.75" rear end more durable than the 8.8"?
Old Jan 17, 2007 | 07:19 PM
thanks for the info
Old Jan 29, 2007 | 07:45 AM
ZelenVR's Avatar
Question
Is there any way to visually determine for sure? I thought they had the 8.8"s also......
Plus, what gear ratio do these run stock?
Old Jan 29, 2007 | 08:43 AM
APT's Avatar
APT
Read my earlier post. If you have the 4.6L, you have 8.8" If you have the 5.4L, you have a 9.75" read gear.
Read your driver's door sticker for the Axle code.
1997-2003 F-150 axle codes:
19 = 3.55 open
H9 = 3.55 LSD
26 = 3.73 open
B6 = 3.73 LSD
27 = 3.31 open
18 = 3.08 open
25 = 4.10 open
B5 = 4.10 LSD
