SuperCrew
Handling Problems
Old Jan 8, 2007 | 01:17 AM
RG24's Avatar
Question Handling Problems
I OWN A 06 FX4 SCREW, I WAS JUST WONDERING IF ANYBODY HAS ANY PROBLEMS WITH STEERING WHEEL VIBRATIONS. THANKS RG
Old Jan 8, 2007 | 05:18 PM
top_sgt's Avatar
when does it vibrate?? highway?? corners?? braking???
Old Jan 8, 2007 | 08:13 PM
YOU SHOULD START BY NOT YELLING AT US!
We need a wee bit more information to help you out, but start simple first. Try taking it to the dealer and tell them it's vibrating.
Old Jan 9, 2007 | 12:59 AM
RG24's Avatar
Sorry for the YELLING the vibration only happens for about five or ten minutes, when i first start driving and then it goes away. It happens at all speeds 0-70, the dealer to me it was just the way the fx4 suspension is set up and their is nothing wrong. Thanks RG
Old Jan 9, 2007 | 05:50 PM
Ash575's Avatar
You could take your truck in to have your wheels checked to see if they are still in balance.
I used to have a good shake in the steering wheel and when I went to have a flat tire repaired they checked the balance in all 4 tires and one was out of balance and not the one I had the flat fixed suprisingly.
There are weights on both sides of the wheel so you could have lost one of the inside if it doesnt look like you lost one from the outside.
Hope that helps.
Old Jan 9, 2007 | 06:04 PM
RG24's Avatar
Thanks for the help I will try these things. Thanks RG
Old Jan 9, 2007 | 06:49 PM
06FX4's Avatar
well since it only lasts for like 5 or 10 min. its pry just flat spots on your tires from sitting...i know my stock goodyears used to do the same thing.
