SuperCrew
Passenger Headlight Went Out, No Reason...
Old Dec 13, 2006 | 11:35 PM
Medjai06's Avatar
A few weeks ago my headlight went out on my passenger side....I figured it was the bulb so I waited to get a new one....That wasn't it at all....I switched out the bulb with a new one and it still doesn't work....Although my brights work,, but only one driving light works....It might be a fuse, but its not the bulb....It might be something wrong with the wiring, not sure....Just wondering if anyone would have any suggestions....
Old Dec 14, 2006 | 11:50 AM
jward's Avatar
Hmmm...... it's not a fuse. If it was, both headlights wouldn't work. Could be that the dim side of the new bulb is bad. I'd swap bulbs with the drivers side to verify. If the swapped bulb still doesn't work with dim, you've narrowed it down to a wiring issue.
Old Dec 14, 2006 | 01:17 PM
Medjai06's Avatar
Yea my friends dad said to bring it down to his shop and run a volt tester on the plugs to see if it's running 12v or not....Ill update the problem...
Old Dec 14, 2006 | 04:36 PM
Medjai06's Avatar
I figured it out....I didn't know there was a fuse for each low beam....I downloaded a manual for my truck b/c I didn't have one....So I checked my fuses, and turns out the RH low beam fuse was blown.....I appreciate the help....THX
Old Dec 14, 2006 | 05:01 PM
jward's Avatar
I didn't know that, either.
Thanks for posting the fix.
