SuperCrew
Loading ATV in Supercrew
Old Dec 3, 2006 | 09:17 PM
hooverone's Avatar
I have a 06 Supercrew 5.5 foot bed, does anyone have suggestions on a good set of ramps to load a Yamaha Kodiak into the bed, I want some that can be strapped down so that the ramps do not slip out.
Do you think the tailgate can support that, I have seen a lot of people do this.
Old Dec 4, 2006 | 01:18 PM
superjay's Avatar
Yes, you can fit an ATV in the back of your truck. Obviously, you need to keep the tailgate down which is no problem. I have heard though to be cautious about stones, ect. coming up off your rear tires and chipping the tailgate while it is down. I personally have never had this problem though, but I also have small rear mudflaps.
I would recommend going with a set of 48-50" wide aluminum ramps. I use the A.P.I. bi-folding 50" aluminum ramp. They have chains on them that can attach to the cable supports on your tailgate for easy "safe" loading. Some ramps are fairly pricey, but they should last you for years!
Good luck!
Jay
Old Dec 5, 2006 | 12:24 AM
hooverone's Avatar
Thanks for that point, I did not think about rocks chipping the tailgate.
Old Dec 5, 2006 | 02:19 AM
crashtheline's Avatar
Maybe get your tailgate 3M'd?
Old Dec 5, 2006 | 10:28 AM
hooverone's Avatar
What do you mean by 3m'd
Old Dec 5, 2006 | 11:43 AM
baddog_44_5's Avatar
Good Ramp
Here's what I use. It fits my '03 supercrew perfect, and the chains are just the right length to clip into existing holes on the side of the tailgate opening. Also, I've found on most larger 4 wheelers, you can fold the ramp and slide it right under the ATV for hauling. I can have the ramps set up to load, or put away literally in seconds.
Here's the link:
http://www.harborfreight.com/cpi/cta...emnumber=90018
P.S. As for the tailgate, I never really thought about it. But it seems to be fine with anything I've loaded.
Old Dec 5, 2006 | 12:52 PM
hooverone's Avatar
That link did not work, is this the ramp you were talking about?
http://www.harborfreight.com/cpi/cta...emnumber=46862
Old Dec 5, 2006 | 01:26 PM
Nope, let me try that again. It is ITEM 90018-7VGA if you want to do a search at harborfreight.
here's that link again
Old Dec 5, 2006 | 01:39 PM
StraitLineRacer's Avatar
Hey man Go Look At i think its truck somthing if u type in truck stuff in google and theres a 4 wheeler ramp and it comes with a thing that ties down for ur bed that might be wat ur looking for
