SuperCrew
Power Moonroof Problem?
Old Dec 5, 2006 | 09:50 AM
fallingUP's Avatar
Question Power Moonroof Problem?
Hi All,
"07" with moonroof my problem,
2 way button , when ya go to close the roof it gets to the point that it shuts but it doesnt seem to stop once its shut, and lifts the back of the roof ???? very nice option but its almost impossible for me to get it to stop shut ????????????????
any help ? am i doing somthing wrong ??? seems to be only problem i have found with this vehicle, with exception of what i think was a stuck injector, would shake at certain point in gas pedal , kicked it down once or twice and problem went away.
Old Dec 5, 2006 | 12:45 PM
APT's Avatar
APT
Does the moonroof do that both ways, like when it is in the vent position, does it stop on it's own when closed or does it continue opening all the way if you keep holding? It should stop in the closed position either way. You should have to press again in order to continue.
Sounds like the sensor is broken or not alighend correctly to know when to stop in the closed position.
Old Dec 5, 2006 | 02:08 PM
fallingUP's Avatar
no it doesnt stop, either way towards back it opens, towards front it closes but doesnt stop then after close it vents but never stops in close position.
