SuperCrew
25,000 Mile Brake Job?
Old Sep 20, 2006 | 04:08 PM
Big Daddy Whiteboy's Avatar
WHOA!!!! BRAKE JOB? WHAT FRIGGIN BRAKE JOB?
JUST A FEW QUESTIONS. HAD THE OIL CHANGED AND TIRES ROTATED TODAY. 25,000 MILES. TIRE/OIL CHANGE DUDE SAID I NEED A REAR BRAKE JOB. WHAT THE #@%*? 25,000 MILES AND I NEED A REAR BRAKE JOB.? HE SAID SINCE I TOWED WITH IT , THIS IS HARD ON REAR BRAKES. MY QUESTION TO THE GAWDS IS .
1. IS THIS A DO IT YOURSELF JOB OR WHAT.
THANKS. OUT. LATE. BD.
Old Sep 20, 2006 | 04:30 PM
02SCrew4x4GA's Avatar
It is extremely easy. Just gotta have a 6" c-clamp and your basic hand tools. i can change the front in about 20 minutes total and the rear in slighly less time (more room to work). make sure you support the frame on car stands. i had an incident trying to use the jack about 5 months ago. Guy bumped the jack when i was putting the tire back on and it came down pinning my hand between the fender and the tire. Hurt like hell.
Old Sep 20, 2006 | 05:24 PM
IL6fan's Avatar
Never heard of such a thing. why would towing wear out your rear brakes? Makes no sense to me. Was it at the stealership? If not I'd take it in there and tell it is premature wear on the rear brakes and I want them replaced. I have 46k on my '03 KR Screw and I've towed my travel trailer with it from day one. My back pads still look like brand new. In fact, after I pull the trailer the front wheels always have a little more brake dust on them than usual, which again leads me to ask, why would the rears wear because of towing? I have yet to change out my pads on my truck with 46k miles on it. They still have more than half the life left on them.
Old Sep 21, 2006 | 10:18 AM
NO IT WAS DONE BY A TIRE DEALER. I THOUGHT THE SAME THING. I WILL DEFINATLY WAIT TILL I HEAR METAL. I'VE DONE THE REPAIRS MYSELF ON OTHER FORDS AND ITS A BREEZE SO THATS WHY I WAS ASKING ABOUT THE DIFFICULTY FACTOR. THAT SAID I THINK THEY SHOULD HAVE PLENTY OF LIFE LEFT ON THEM ALLTHOUGH I DID NOT INSPECT MYSELF.LATE OUT BD
Old Sep 21, 2006 | 10:48 AM
brandonhadnot's Avatar
LOL at the brake job...
did you get to use lube when you that tire dealer bent you over and gave you the shaft? only problem i have with brakes is..... i tow something my pedal gets real spongy next day i have to get underneath and adjust the drums.. no matter what i pull the pedal gets spongy... dont have any leaks but or loosing fluid just seem wierd that i have to adjust so often never had a truck act that way till i got this one.. 99'xlt sport excab 4.6l
Old Sep 21, 2006 | 11:55 AM
ws6_guyscrew's Avatar
hmm i'd suppose new pads and turning the rotors may be neccessary, but getting new brakes in the year big rip off. Not that extream of a job.
Old Sep 21, 2006 | 12:00 PM
Have you tried adjusting them with the "star" adjuster. The drums should automatically adjust themselves when you apply the brake while in reverse. Meaning back up to about 10 mph and push the brake pedal. Always worked on my Silverado.
Old Sep 25, 2006 | 09:19 AM
ya i have... thats how i adj stick a flat screw driver in the back and adj.. ... but the backin up thing dont work.. im guessing the teeth on the adj.. are slightly worn...
Old Sep 26, 2006 | 10:50 AM
redbaron's Avatar
Angry rear brakes???????????
i have an 05 screw and i had fronts replaced (rotors, pads, calipers) all done under warranty at 18,000, now they say my back rotors are warped and need replaced (dealer says they cannot be turned) i have 34,000 now and have been DISCUSSING this with ford for 10,000 miles they say it is to be repaired on my dime. my pads look like brand new, but warped rotors????????? never before had such a problem. The dealer mechanic told me (off the record) that they are cheap rotors made of cheap steel, and the brakes are too small for such a heavy truck. all said and done it doesnt matter why they are having trouble with the brakes they should fix them and make the consumer happy, maybe then they wouldn't lose so much money. (just my opinion)
Old Sep 26, 2006 | 03:37 PM
hmm well every company probaby builds the brake system so you updgrade it, or either kjeep comming back for repairs, they gotta make small change somehow i guess, I know thats how must GM cars are, good cars, but lousey brake systems.
