SuperCrew
Lightning front on a Supercrew?
Old May 9, 2006 | 05:25 PM
ws6_guyscrew's Avatar
Originally Posted by screwtech02
Ill get some pics of it this weekend guys, i have the lower, and upper grill inserts also, the fascia is black, and will need repainted, it has some chips around the fog lamp openings....
awesome man, chips no problem can be fixed
Old May 11, 2006 | 02:28 AM
Originally Posted by GA Southern Eagle
I have the L bumper on my Truck. Just remove all the plastic black trim peices and you will need two additional support brackets and it fits directly over the chrome bumper. I also have the upper and lower grille inserts and headlights and tail-lights. The rims from 01 have ben added and I even found a company in CA that sells ground effects fo the supercrew that look like stretched lightning ground effects. I essentially have a 4 door look alike with out the engine.
Good luck with you project. Here is a pic
one more before the pinstripes and ******* tonneau
Im guessing you bought a knock off Lightning bumper, because i was under the impression that the chrome and painted OEM bumper pieces come off, and the new one bolts onto the real bumper, and not just "slipping over the chrome bumper" as you describe
-Patrick
Old May 13, 2006 | 03:20 PM
bd4martin's Avatar
I put a lower valance on my old truck. I liked it better than changing the whole bumper.
I still have the wheels if anyone is intersted just email me bd4martin@yahoo.com
Old May 13, 2006 | 03:57 PM
Norm's Avatar
-Patrick
It (OEM) will slip right over the chrome bumper after you remove the top plate and valence. You can remove the chrome piece if you want and replace it with a black version of the same thing but there is no reason to do so.
Old May 15, 2006 | 01:57 PM
GA Southern Eagle's Avatar
That is correct about fitting over the chrome bumper. Just remove the plastic peices. Everything is OEM Ford except my ground effects.
Old May 15, 2006 | 02:45 PM
keypilot's Avatar
i found this one.
opinions welcome
http://www.abcexclusive.com/F150_97.htm
Old Sep 2, 2006 | 09:49 PM
Originally Posted by keypilot
i found this one.
opinions welcome
Looks great! I think i'll order that bumper in a couple months. I'm still trying to get a Lightning bumper & I have seen some on ebay that have custom vents on the sides and all they look terrible. Then i'll just need to get it primed painted & clearedn, get fogs, and a billet grill for it & i'm set!
Old Sep 2, 2006 | 09:52 PM
I have never seen those before, kinda cool, but I want to get rid of my chrome, plus in my opinion it looks better without seeing all the part lines ( top cover, chrome support piece, then the lower valance ) the Lightning bumper creating that all in one piece, much cleaner
Old Sep 5, 2006 | 05:37 PM
secstang03's Avatar
which lower is this?
Old Sep 8, 2006 | 08:01 PM
OneHotLX's Avatar
What did you end up using for exhaust? I've been thinking about getting a cat-back for my 02. And I've been wondering if anyone has ever taken a Lightning cat-back and put it on a Supercrew. I'm assuming you'd have to add some length to it but I'm not sure about the hangers.
Old Sep 24, 2006 | 10:39 PM
Why not just get Flowmaster? or Magnaflow?
Old Sep 25, 2006 | 05:59 PM
bd4martin's Avatar
That valance on my old truck is a Street Scene Gen II valance.
