SuperCrew
Fog light/parking light question
Old Dec 20, 2005 | 08:07 PM
Chapman's Avatar
Can someone give me the link to wire up the fog lights so they work with the parkings lights and the high beams? Im sorry if this has been beat to death, but Im at work right now and have little time for searching. Thanks in advance.
Old Dec 20, 2005 | 11:22 PM
TruBluSuperCrew's Avatar
Wish I could help, I do remember what you are talking about. You are probably going to need to make some time and do the search. Good luck.
Old Dec 21, 2005 | 03:04 AM
THall's Avatar
Headlight mod link
There are a number of them ....... here is one.
http://www.svtlightnings.com/svt/how...s/foglamps.htm
Tom
Old Dec 21, 2005 | 06:50 PM
Chapman's Avatar
Thanks for the link.
Old Dec 27, 2005 | 03:58 PM
mikeyss's Avatar
Does anyone know how to do this on a 99'? The wiring is alittle different, so is the switch.
Old Jan 9, 2006 | 06:21 PM
colinm's Avatar
My 99 has different wiring setup but the switch mechanism is still similar in design. Could someone please describe what wires must be spliced to complete the electrical modification?
Old Jan 9, 2006 | 07:47 PM
cpaggie_07's Avatar
Here's another link with the exact same info. But you'll notice at the top, there is a paragraph that tells you that spilicing the #2 and #12 wire together (making the fogs turn on w/ the parking lights) will burn out a fuse. Is this a problem, or what? Correct me if I'm wrong, but the end result is:
Fogs work with parking lights on.
Fogs still work with head lights on.
Fogs also work with autolamps.
Old Jan 9, 2006 | 07:56 PM
colinm's Avatar
Ok... so I pull the headlight plate. Undo all of the harnesses and take the part inside for studying. As I disassemble the switch I pull too hard on the headlight **** and all of the sliding black switches and copper conductors and micro springs fly apart. Well, needless to say, I invented a few new expletives. After an hour of work with an ohm meter I have the switch reassembled and working again. Now I'm solving what circuits must be closed for the fog lights to be activated in park. I did not realize how complex this procedure could be after the mechanical modification. By the way, it is a 99 non-autolamp non-drl with stock foglamps. Give me a bit and I will find what wires must be spliced in the harness to achieve fog lamps and parking lights only. Being a 99 this electrical mod is different than that of the lightning 01 screw mod. Once I figure it out I am considering making a step by step procedure with pics so that you 99 guys can take a crack at it. If anyone has already done this please save my dead horse beating.
Ok, just found the article....that concludes this rant!
Old Jan 14, 2006 | 01:12 AM
At whatever point i put mine in i would probably just set up a seperate relay/ switch so they can be independently operated. No need for them on a daily use IMO....
-Patrick
Old Jan 14, 2006 | 10:33 PM
jpdadeo's Avatar
here's another link, this is the one I used
https://www.f150online.com/forums/sh...hreadid=181125
