SuperCrew
want to grease the truck, but have ???
Old Apr 12, 2005 | 03:56 PM
mcvey90's Avatar
I was changing the oil today in my truck, when I decided it was time for a chassis lube.
I could only find 2 zerks though, both at the front of the truck on the passengers side. I looked everywhere but it seems that most places that I would think needed grease all had rubber bushings instead of grease zerks.
There has got to be more than 2 spots to grease these things.
any help would be appreciated.
its a 02 F 150 supercrew if that helps anyone.
Old Apr 12, 2005 | 04:34 PM
max mitchell's Avatar
Welcome ! You're correct, there are only the 2 zerk fittings on the idler arm. You can buy a injection needle grease gun fitting and lube the rest by carefully piercing the boots.
Old Apr 12, 2005 | 04:46 PM
RockyJSquirrel's Avatar
NAPA part number 700-1193
For $6 you get two injector needles.
Old Apr 12, 2005 | 05:13 PM
mcvey90's Avatar
how hard of job is that to do. I don't want to ruin anything. If I took it to a dealership for a chassis lube, what would they do. Just the two zerks or would they puncture the boots like you say.
where are all the boots that need punctured??
I'm fairly certain I can handle this, just want to be sure.
thanks again
Old Apr 12, 2005 | 05:17 PM
bigtruck311's Avatar
if you do inject the other bushings with the needle be very carefull it is very easy to tear them after the needle has been inserted, i tore one of mine and it pissed me off, just be carefull once the needle is in
