SuperCrew
Anyone replaced pinion seal themselves
Old Mar 21, 2005 | 09:26 AM
01GreenCrew's Avatar
My pinion seal has a slow leak and I would like to replace it but I don't want to pay someone else to do what I can. Has anyone changed this themselves? If so, how extensive is it? I would assume you have to pull the axles out. Remove the ring and pinion assembly and the driveshaft to get the old one out.
Old Mar 21, 2005 | 10:34 AM
max mitchell's Avatar
Well, yes and no. Typically, shops drop the driveshaft, measure the pinion preload, pull the pinion nut and companion flange, pry the seal out, install a new seal, slide the companion flange back on, slowly tighten the OLD pinion nut back down to the original pinion preload, and re-install the driveshaft. It's quick, easy, and all done up front. There are several problems with this method: A) The crush sleeve is a one time use part and complete axle disassembly is required to replace it. B) proper pinion preload is measured with only the pinion assembly installed in the housing with a new crush sleeve; once again, requires complete disassembly. C) Pinion nuts are one time use items. So, what you have is a choice. A smart mechanic that replaces it with the first method would offer no guarantee.
Old Mar 21, 2005 | 11:36 AM
Thanks for the reply, I might just check around to see what a good shop would charge. My main problem is that I don't trust anyone else with my stuff, so I usually do it myself.
Old Mar 21, 2005 | 12:00 PM
You're Welcome ! I completely understand and agree. Good luck !
