SuperCrew
Overhead Temperature Indicator is Way Off,
Old Feb 14, 2005 | 08:59 AM
Racer70's Avatar
My 2001 Screw Overhead Temperature Indicator has a problem. It isn't reading the temperature correctly. It is 10 to 20 degrees too high.
Does anyone have a fix for this?
Old Feb 14, 2005 | 09:03 AM
Rinkrat's Avatar
I forget...but its in the manual for my 02 Screw
Old Feb 14, 2005 | 09:32 AM
Racer70's Avatar
Thanks, but I didn't see any info in the 2001 manual.
Old Feb 14, 2005 | 09:58 AM
Rinkrat's Avatar
I apologize...it shows how to calibrate the compass but not the temp.
That is a good question....sorry
Old Feb 15, 2005 | 11:11 AM
DANZITSCREW's Avatar
Been there
I had the same problem for a while. What I did was go to where the probe is, I believe on the right front of the radiator shroud, and found lots of rust on mine. I clean it and painted it and it was right on. This worked for me, mine is a 2001 as well.
LT Dan
Old Feb 16, 2005 | 10:11 AM
snappylips's Avatar
Replace the temp. sensor. Remove the radiator cover, and you'll see a small two-wire sensor on the drivers side in front of the radiator. Read these two threads: https://www.f150online.com/forums/sh...hreadid=183606
https://www.f150online.com/forums/sh...hreadid=185798
SL
Old Feb 16, 2005 | 05:18 PM
Racer70's Avatar
Thanks,
Hey Guys,
Thanks for you help. I'll check it out this weekend.
Old Feb 16, 2005 | 07:36 PM
ICD8EM's Avatar
Re: Overhead Temperature Indicator is Way Off,
Drive South for about 500 miles and it will be correct!
