SuperCrew
dash sqeak
Old Jan 30, 2005 | 09:59 PM
slowrancher's Avatar
dash sqeak
has anyone had or found something causeing a bad sqeak coming from under the passenger side dash.i cant find the cause for anything.
Old Jan 30, 2005 | 10:05 PM
lrhogfan's Avatar
Occasionally, I will have the screws from the bottom of the passenger side door come loose and that causes some squeaking???
Old Jan 31, 2005 | 07:00 PM
I'll check that
Old Feb 15, 2005 | 08:45 AM
hawkfxr724's Avatar
Mine too!
My dash squeaks on the driver's side from somewhere near the pedal adjuster panel area. I've taken the paneling off and applied weatherstripping to some of the area, but it still squeaks. Here's the weird thing, it only does it at temp's below 35 deg F. Crazy, huh?
I reckon I need to apply more weatherstripping or move farther south!!
Old Feb 16, 2005 | 10:02 PM
chucks bp's Avatar
My 2001supercrew dash squeeked on the passenger side esp in cold weather, I removed the top piece that pushes on and made cardboard washers to put under screw heads that hold dash to metal then I put a little silicone brake lube (jell) on the clips before I reinstalled the trim, 18 months and no noise!!!
