SuperCrew
Cruise control question
Old Dec 23, 2004 | 02:30 PM
GrizfromKY's Avatar
My cruise crapped out on me the other day. I checked the fuse and it was good. Any ideas, or am I headed to the stealership?
Old Dec 23, 2004 | 05:22 PM
Bluegrass's Avatar
About the only thing you can look at is the brake switch that kicks it out when the brake pedal is applied, unless you have service info to go further.
This system is a stand alone with an amplifier controling the serco unit.
The amp is under the dash, possible the connector has come loose.
Other area is the steering wheel switch and spring assemblies and cabling.
Old Dec 23, 2004 | 10:57 PM
Gearhead99's Avatar
Jump the switch at the mastercylinder and see if it will work.
You'll probably be surprised that it the bad fault.
Old Dec 24, 2004 | 11:38 AM
GrizfromKY's Avatar
Thanks Gearhead! I'll give it a try. Merry Christmas to you and yours!
Griz
