SuperCrew
Penda Liner
Old Oct 13, 2004 | 12:11 PM
Steve Corley's Avatar
Penda Liner
I purchased a Penda Bed Liner for my Super Crew. It has large holes on each side to allow access to the tie down points at the front. I think this is a very poor design. Does anyone have any suggestions other than duct tape and card board when hauling lose material?
Old Oct 13, 2004 | 03:20 PM
ChasingNolan's Avatar
My Pendaliner came with rubber plugs that cover up the two front holes when not in use. You can pop them out when you need the tie downs. Maybe this is something you can get from Pendaliner?
Old Oct 13, 2004 | 04:16 PM
Penda Liner
I got an e-mail form Liz @ Penda and she has offered to send me plugs to fit the holes, but warns that the tie down hard ward might stick out too far and prevent their installation. I will measure the holes and get back with her. Maybe this will fix it.
Old Oct 13, 2004 | 05:34 PM
tsc's Avatar
tsc
What about cutting out a hole for the tiedown from the center of the plug (using a dremmel). The plug would then slip over the tie down and you could use a silicone to seal the hole. Just a passing thought.
