Power seat swap / 99 excab to 01 S-Crew
I have a 2001 F150 Supercrew that came with non powered seats. I swapped out the power seats from my 1999 F-150 extended cab. The swap bolts right in. I kept the 99 pigtail in order to tie in with the power seat lead from the 01 Supercrew. Can anyone help me with several questions:
1. Does any one know if an 01 Supercrew without power seats has a power seat lead tucked away in its wiring harness and where I could find it?
2. If the 01 Supercrew did not come with a powerseat lead, does anyone have any helpfull hints as to how to get one, either salvage yard, OEM, or aftermarket?
3. Does anyone have any helpfull hints as to building your own out og 10 or 12 guage wire and tieing it with the fuse box? Thanks, BW
on
First, is your SCrew a XTL ?
If so it should be under the carpet, mine comes up under the center of the seat. If you follow where the harness for the seat belt latch is at, it might be right there, if not, let us know and one of us will EVTM you to death with the harness.
BTW : is it the same 6 way power seat config ?
