Bulletin from Ford
Originally posted by mudd1
not sure if a alignment is needed. but if it was needed then they should have done it after replacing the part... call and ask them.
Thanks, Mudd1, for your help. Did as you advised. Dealer said that alignment was not required for the replacement. My uncle drove it and found the same drift to the left as I did. He crossed the front tires and it cancelled the drift. He says this indicates "run-out" in one of the tires. I'll take it in this week to a great tire shop I found, have the tires checked and probably do an alignment as well.DeeAnna
