Power Windows F150 Supercrew 2003
i have a hunch but i think it is the door switch but am not sure.
as well as for my screw it has no power windows or interior lights (dome and door lights) or no wipers !!!!!!!
supercrew window switches
I had the same problem and got all 4 working by cleaning/adjusting the switches. Remove the master switch cluster from the drivers side. Use a small screw driver and take the it apart, fairly easy. You will see contacts for every switch. Use sand paper and clean the contacts. Some are a bit hard to get to but it is possible.Then I sprayed carb/contact cleaner on all the contacts. Get the small screwdriver and push on each spot that the buttons push on to mach sure that everything lines up and actually touches. If some don't they can be bent back easy with the flat screwdriver. I had quite a few with this problem. Some of these contacts should always be touching. You will know what I mean when you see it.
