SuperCrew
oil ?
Old May 12, 2004 | 08:56 PM
jmorg1980's Avatar
oil ?
Ive been using motorcraft 5w30 in my truck and was thinking about switching to 10w30 since it gets pretty warm here in the summer and I was told its better to have a thicker oil if its warmer temps? I dont really know anything about it what are your opinions and what is your take on this higher milege oil is it a marketing host or is it for real? My truck is ticking close to 100k and was wondering if I should use it or not Motorcraft doesnt have it so if I switch what should I use? Id appreciate the help.
Old May 13, 2004 | 04:04 AM
retired2001's Avatar
Oil
I've been using Castrol GTX 10W30 for 30000 miles, but I just switched back to Motorcraft 5W20 (Ford recommended & synthetic). For some good into on oil check out: "http://www.bobistheoilguy.com/" More info' than you may ever be able to use, but very informative.
Old May 13, 2004 | 07:46 AM
jmorg1980's Avatar
If your not using synthetic and you switch to it do you have to do anthing special?
Old May 13, 2004 | 06:00 PM
mudd1's Avatar
ive heard you need to flush it out if you want to go to synthetic, not really sure though.
Old May 13, 2004 | 09:19 PM
rajuncajun37's Avatar
i use 5w20 Motorcraft in my 2003 5.4 year round,
all my other rides I use reg oil with 1 Qt. of SYNTHETIC added to it to give it a blend, this way i know how much of a blend i have where as when you buy (syn blend) you have know idea what the ratio is of syn
Later ,,
Mark
Old May 14, 2004 | 02:55 PM
Schmoe's Avatar
The Motorcraft 5W-20 is NOT synthetic, it's a blend. It does hold up well in used oil analysis. A lot of F150 owners are running M1 5W-30 for 5K and not having any problems. Would recommend that you use the Motorcraft filter, FL820S, these are good filters and made by Purolator.
Old May 15, 2004 | 01:53 PM
TonyPTX's Avatar
Ford flip flops on the manufacturer of the MC filters. It's either made by Purolator or sometimes Champion Labs.
Old May 17, 2004 | 06:38 AM
messman24's Avatar
I have been useing Mobil 1 0w20 for about the last 10000 miles i do get a 1 mpg increase over 5w30, the 0w20 from what mobil said is 5w20 compatible, but now the local walmart stop carring it.
Old May 20, 2004 | 10:31 AM
beerme's Avatar
Oil for what its worth
I have an 03 FX4 that I bought new a year ago. At that time I found a post on here that spoke about Mobil 1 10w-30 Full synthetic being a great oil for the 5.4L's. I used the same oil in my 99z28 LS-1 before I traded it for F150 and in both vehicles without any problems. I live is central florida between Tampa and Orlando so it gets fairly warm down here. My truck has 25k on it and I have been using that oil since my first oil change at 1500 miles. No complaints and I will continue to use it as I am a believer in the Mobil 1 synthetic product. I cannot speak about the quality versus other vescocities and brands all I can say is it works for me.....Gook Luck......
Old May 20, 2004 | 10:45 AM
jpdadeo's Avatar
I use Motorcraft 5W20 & Motorcraft filter.
Change it every 3 thou.
My dealer offers lifetime FREE oil changes.
Old May 20, 2004 | 03:37 PM
nick-h's Avatar
I have used M1 for years and have had no problems. As for filters, K&N has less than 3 PSI drop, better than most. I read it on a post from the thunderbird, cougar club of america web site. Simply, if you change your oil regularly, you should have no problem assuming you use a good quality oil.
Old May 24, 2004 | 01:30 PM
TXLerxst's Avatar
I have found success and better performance since switching from Mobil 1 Oil & Filter to Royal Purple 5W20 w/ K&N oil filter. Costs a bit more - yet noticeable improvement
Old May 24, 2004 | 08:28 PM
max mitchell's Avatar
Re: oil ?
You are not getting a thicker summer oil with this switch. They are both "30".
