SuperCrew
Need braking help
Old Nov 22, 2003 | 12:56 PM
DANZITSCREW's Avatar
Question Need braking help
I recently moved to Italy and my Supercrew finally showed up, thank god. Anyway, I live part way up an active volcano and part of the road to and from my house is very steep. It has a pretty steep angle (15-20%)for about 4-5 miles in pretty much a staright line. I have started taking the truck out of overdrive to help slow me down without using the brakes. I also have downshifted to 2nd gear to aid in slowing me down. I want to preserve the tranny and the brakes, any suggestions? Can you see any problem with how I currently use the tranny on the hill? Is there a compression/exhaust brake for a gasoline engine? Any suggestions are greatly appreciated. I put Rabestos brakes/ rotors on right before we moved, so they are new. Thanks in advance for the help.
Dan
Old Nov 29, 2003 | 12:41 AM
Rockpick's Avatar
Moderator &
Dan,
I just thought I'd bring this one back to the top so that it may get a few more looks. Also, you might consider posting the same question up in the 'BRAKES' forum near the top of the forums list as you'll probably get a few more guys that know a little more about it giving it a look.
Oh yes... where are my manners?
---> WELCOME TO f150online!!!<---
RP
Old Dec 1, 2003 | 01:54 AM
Thanks. I appreciate the help and suggestion.
Dan
Old Dec 1, 2003 | 09:47 AM
ReelWork's Avatar
DANZIT...
The hell with the brakes, you live on an active volcano!
Seriously though, I always use this train of thought in situations like you mentioned. A set of brakes are a heckuva lot cheaper than a tranny rebuild.. I would probably do just what you're doing...
I don't believe that there is a compression/jake brake for a gasoline engine since the compression is so much less... But, I could be wrong there..
Later,
Chris
Where are you anyways? Sounds like Aviano or Naples?
Edit, never mind, I looked at your signature and saw that you clearly stated Sigonella... It's Monday!
