SuperCrew
Towing In The Mountains ?
Old Oct 21, 2003 | 09:12 AM
Big Daddy Whiteboy's Avatar
Cool Towing In The Mountains ?
ANY POINTS OR TIPS OR WARNINGS ABOUT TOWING A PULL TYPE CAMPER IN THE HILLS OF TENNESSEE. WILL BE TOWING NEXT YEAR AND WOULD LIKE SOME POINTERS.
Old Oct 21, 2003 | 09:27 AM
ReelWork's Avatar
Pointers?
MAke sure you are OUT of OD, to be more specific, have it turned off! Watch the temperatures and oil pressures, as you would normally do and tow away!
I would suggest you have your cooling system checked, brakes checked and do an oil change on the engine just prior to going.
As for the trailer, check tire pressures and make sure your hubs are lubed up. If it has brakes, check that they are operating properly.
Have a good time!
Chris
