SuperCrew
Undercover Anger Management?
Old Oct 2, 2003 | 08:35 PM
tbbr's Avatar
Question Undercover Anger Management?
I have seen lots of positive comments about the Undercover tonneau bed cover. Just wondering if on the flip side anyone had
regrets about buying the cover? I mean, nothing is perfect, right?
How well has the cover held up over time since your purchase?
Does the wall hanging storage set up really work as a means to get the cover up and out of the way?
Is the cover truly easy to take off and put back on?
Anyone painted it?
Old Oct 3, 2003 | 12:29 PM
SCREWDINOK's Avatar
Undercover
1. Like new
2. Yes
3. Yes, if you follow the directions. (release struts first, then
disconnect front tabs)
4. No, but I like the black as it does not visually change the
profile of the bed. So the profile of the truck looks like an
F-150 instead of an Avalanche.
And I can't believe I waited so long to get one.
Old Oct 21, 2003 | 12:56 PM
Superbru's Avatar
Thr Undercover is everything they say it is in the web site writeups.
It is secure, water tight, lightweight, and durable.
Also, easy to install - less that 1 hour.
Look at Truck-Bed-Covers.net
Old Oct 21, 2003 | 03:29 PM
Krix330cic(NJ)'s Avatar
how "textured" is the material? very deep, or is there a good shot at smoothing it all out?
Old Oct 21, 2003 | 04:44 PM
Rollwave88's Avatar
Have had it 3 years and still no regrets. The only issue I have had, which I have stated in a previous post, is with the brackets that secure it. They did not have a durable finish and would form rust when scratched. I fixed that problem by putting a thin coat of Herculiner on them. This has worked great to prevent the rust problem.
Old Oct 22, 2003 | 10:41 AM
EkimLesondak's Avatar
I have had my Undercover for about 6 months and no regrets at all! I have had to remove it many times and I am able to do it by myself and it only takes me a few minutes to do it. I too have noticed some rust forming where the pins go on the hinge but a simple spray of Black paint solves that. I personally like the black cover and have not seen one painted. The texture is not too rough and from a distance looks smooth. I have had no problems with dirt and gunk getting lodged in the texture of the cover. If you are looking for a hard cover I would recommend the undercover from Truck Bed Covers 100%!!!
-Ekim
Old Oct 22, 2003 | 10:49 AM
elmolangley's Avatar
Only negative would be if you were out of town and found something you need to haul back home without the cover, what would you do with it ?
