SuperCrew
leveling kit?
Old Oct 6, 2003 | 11:02 AM
jesterstruck's Avatar
leveling kit?
Where can I get a 2 inch leveling kit for an 01 with the 5.4? Does anybody here have one? Are they worth it. Thanks
Old Oct 6, 2003 | 04:03 PM
wandell's Avatar
Do you have a 4x2 or a 4x4? If you have a 4x4, just crank up the torsion bars because there is no leveling kit available. If you have a 4x2, Daystar makes coil spring spacers and Fabtech makes lift coils for the front. Or you can add drop shackles to the rear to lower it.
Old Oct 10, 2003 | 02:37 AM
FyrDawg2's Avatar
Level out a 4X2
Check this thread:
https://www.f150online.com/forums/sh...843#post307843
Old Oct 12, 2003 | 09:30 PM
sorry its for a 4x4
Old Oct 13, 2003 | 10:42 PM
RebelYell's Avatar
If you have a 4x4, all you have to do is "crank" your torsion bars. Simple mod. Takes about 15 minutes if you are familiar with it, about 30 if you have never done it before. The best part is...it's FREE!.
I have typed this so many times, so I'm just going to tell you to Use The Search Button. Search for... torsion, bars, lift, level, etc, etc. You should get the results you are looking for.
Good luck.
