SuperCrew
H13, how did you do this?
Old Aug 12, 2003 | 01:54 AM
CJW's Avatar
CJW
Hi,
How did you Eliminate the "Key in Ignition Warning" .
Chris
Old Aug 12, 2003 | 08:57 PM
sk8inrj1's Avatar
I would alos like to know how you did this mod H13.
Old Aug 13, 2003 | 10:37 AM
bloomquist's Avatar
ditto here
Old Aug 13, 2003 | 10:49 AM
closer9's Avatar
Take the key out!
Old Aug 13, 2003 | 10:44 PM
H13's Avatar
H13
LOL, closer9 you funny.
You have to bend a little tab that makes contact with the key cylinder.
You insert a center punch in this hole that is below the cylinder on the column.
Turn the key if necessary, I can't remember exactly it's been a few months. It took me a minute to figure out how to remove the cyliunder, but it wasn't hard.
Once the cylinder is out, there is a metal spring tab that contacts the ignition cyclinder. I tried pressing it down like some others have said to do, but that didn't work for me. Others have said to put tape over it or just break it off. What I did was bend it forward, then reinsert the cylinder.
You can leave the key in the igniton while it is in the "Off" position with it not making any noise. The other positioons are controlled by the computer, so they still ding. Not a perfect ding removal procedure, but it worked for what I wanted.
